question about valve cover
Old Aug 12, 2010 | 09:22 AM
sh!ft's Avatar
Who the fack changed my title?!
Default question about valve cover
when going to add -an fittings onto a valve cover, do you drill a hole through the baffeling as well or just through the primairy metal infront of the baffeling?
Old Aug 12, 2010 | 12:33 PM
g-gameslude18's Avatar
Default Re: question about valve cover
Either. If you tap into the area that is not baffled then you will gather more oil in your catch can.
Old Aug 12, 2010 | 01:06 PM
redboost10's Avatar
just drill through the outter wall of the front of the valve cover, it will vent just fine doing it like that. some will add another two vents to the back of the valve cover and will weld some baffling pieces to limit the oil venting into the catch can
toshiyuki
Apr 21, 2017 08:38 PM
yyyktk1
Aug 10, 2014 04:08 PM
Mr. Em1
Welding / Fabrication
10
May 2, 2009 03:38 PM
