SKUNK2 K-Series(K20A2) Camshafts part# 305-05-0220 - $375
SKUNK2 RACING STAGE 1 CAMSHAFTS (part # 305-05-0220)
Compatible with the following vehicles:
K20A2~Z Stage 1 Camshaft Set -
RSX Type S (2002-2004),
RSX Type S (2005-2007),
Civic Type R (2006-2009),
Civic Si (2006-2009)
I pulled the compatibility list from a website, correct me if the list is incorrect. Rest assure that these are the actual Skunk2 camshafts with the "S2" symbol stamped on each shaft.
"Skunk2 Racing camshaft profiles are designed using the latest computerized valvetrain and modeling techniques to maximize horsepower and torque. The camshaft blanks are cast from the same foundries used by auto manufacturers such as Toyota, Nissan, Honda, and Mitsubishi, and utilize the latest in Japanese chill-casting technology. Skunk2 Racing camshafts are ground to exact specifications using CNC cam grinding machines and are subjected to hours of performance and durability testing. Skunk2 Racing camshafts must pass stringent quality control standards that exceed OE requirements."
"Stage I: Stage I profiles are designed to offer the widest possible powerband and be compatible with factory valvetrain components. These camshafts are designed to retain stock idle and are currently CARB Exempt. Upgrading to Skunk2 Racing valve springs is recommended. Stage I profiles are relatively easy to tune for maximum power output."
Contact info : Call/Text (615)438-5772
WILLING TO SHIP AT BUYER'S EXPENSE
L.A.OutlawFWD
Apr 21, 2011 10:56 AM
