Texas -OK -LA (Sales) Texas, Oklahoma, Louisiana
TASCAM CD-RW900SL Slot Load CD Rec w/ MP3 Playback
Old Aug 12, 2010 | 06:32 AM
fracas's Avatar
Icon6 TASCAM CD-RW900SL Slot Load CD Rec w/ MP3 Playback
TASCAM CD-RW900SL Slot Load CD Rec w/ MP3 Playback - $350
Building on the success of the CD-RW750, the CD RW900 adds MP3 playback, pitch and key control, a key board input and more to an already packed feature set. MP3 playback is provided with ID3 tags, so you can read the names of tracks as they play. The user can navigate to directories on the CD, so MP3 fi les can be organized into folders before burning. Pitch control is also a standard feature, with up to 16% control over playback. A new function called Key Original changes the playback speed without affecting the pitch. The new PS/2 keyboard input offers not only the ability to name tracks using CD Text, but gives the user one-key access to frequently-accessed menu functions. The CD-RW900 is a professional CD recorder that fi ts into 2 rackspaces. It features unbalanced RCA inputs and outputs, as well as S/PDIF digital ins and outs via optical and coaxial connectors. Dedicated analog input controls are provided on the front panel, and a digital input trim is also controllable. Using TASCAM CD recorders is simple, which is why they??re the fi rst choice for houses of worship, schools, and other contractor and consumer applications. Retails for $499
2U rackmount design
+16%/-16% pitch control in 0.1% steps (CD audio discs only)
MP3 Audio Playback
Key Original (CD audio discs only) - change the playback speed without changing pitch
Dedicated analog input level controls
Digital input level control
Fade in/fade out recording features
PS/2 keyboard input
Auto track increment by level with trim function
Automatic sample rate converter (to 44.1kHz, defeatable)
Un-finalize for CD-RW
All, single, program, random play and repeat play modes
Power-on play ?C starts disc playback when power is applied for installed applications
CD Text and MP3 ID3 tag display
Unbalanced RCA inputs and outputs
Coax and Optical S/PDIF digital inputs and outputs
Wireless remote control
http://www.pssl.com/!YkjyFabiGUeVR2U...MP3-Playback-s
Was in a SMOKE FREE studio. Never Abused. Used a total of 10 times if I was lucky. Use it for demos only.
$350
Will accept trade. Looking for Dj equipment, Sound Equipment, Tvs, Laptops, Home Pc's
Old Aug 16, 2010 | 05:32 AM
fracas's Avatar
Default Re: TASCAM CD-RW900SL Slot Load CD Rec w/ MP3 Playback
ttt
fracas
Aug 13, 2010 10:14 AM
wushubrian
Feb 12, 2006 08:51 AM
Civic97s
Audio / Security / Video
Nov 29, 2005 07:32 PM
