code 43
Old Aug 11, 2010 | 09:46 PM
ejfromwestbay's Avatar
Default code 43
got code 43 on a 90 accord ex ecu got an extra ecu that is confirmed to work got a good working starter and a new distributor and new battery and a 3 month old oxygen sensor. why does it not start.? could it be anything but a fuel pump? if so what? how do i diagnose further? and any body got any links to install a two piece cold air intake
Old Aug 12, 2010 | 12:49 PM
sgraham01's Avatar
Default Re: code 43
listen for fuel pump activation upon switching the ignition on. if no sound, check your main relay.
Old Aug 12, 2010 | 12:58 PM
Default Re: code 43
forgot to mention got a new one from honda
Old Aug 12, 2010 | 01:01 PM
Default Re: code 43
and the car did start today found out it was a simple fix the battery connections ,but still have code 43 so i cleared the computer and installed a short ram air intake instead of cold cause the second pipe i had too many problems with. the idle problemm seems to be gone ,but not gonna drive it till tomorrow. need to get it fixed if code 43 stays so i appreciate any suggestions for the diagnosing or fix
shoklid
Apr 28, 2009 06:19 AM
89 pos
Sep 13, 2004 03:04 PM
ucacrx
Jan 1, 2003 08:24 AM
crx_91si
Jan 22, 2002 05:06 PM
