speedo gauge/ fuel and temp dont work
Got my car back from getting inspection. Drove home everything was fine and worked. went back out to go pick up my daughter and car wouldn't start. checked the battery connector and car beep (left keys in ignition) and got power, turned on the car look at my gauge and both needle was at zero and fuel and temp gauge was not lit. turn on head lights speedo gauge illuminated but needles still sat at zero. sunroof don't work either and my window to but side mirror is was about to adjust. Turn signal light don't work except when emergency is on. Checked fuse everything was fine. Please help!!!
i have a 92 lude for parts i'll use the fuse from that one. But what about my speedometer and fuel/temp gauge not working.
Another thing i forgot to mention. when the car didn't start i wiggle the negative terminal and the car received power but i also notice that my ground wire to the frame from the negative terminal was nearly coming off. i think that's what caused my car to not start at first. can this cause a blown fuse?
What is your current vehicle? You never specified, and it does matter.
Yes, that can blow a fuse. Check them all. And you don't need to pull fuses out of another car. You should already own replacement fuses. You can get a pack of 10 from walmart for like $3.
aznnikeballer887
May 5, 2008 11:08 PM
aznnikeballer887
Sep 16, 2007 01:06 AM
1999, civic, dont, ef, fuel, gauge, honda, inoperative, odyssey, reasons, speedometer, temp, temperature, work, working
