Which throttle body?
Old Aug 11, 2010 | 06:23 PM
g-gameslude18's Avatar
Default Which throttle body?
I have been thinking about upgrading the throttle body on my custom intake manifold. I am on the fence as to which one to go with. I would like to use at least a 75mm t/b. I found 2 that I think would work pretty well. One is a universal 80mm ebay unit. http://cgi.ebay.com/ebaymotors/80mm-...Q5fAccessories
The other is a ls1 throttle body with a 94mm inlet and a 75mm plate. http://cgi.ebay.com/ebaymotors/NEW-G...ts_Accessories
I was wanting to know if anyone has used either and what issues that they have had i.e. plate sticking or fitment issues. The manifold it is going on is similar to the last one that I made.
Old Aug 11, 2010 | 06:48 PM
Jdm_Ego's Avatar
Default Re: Which throttle body?
did you make that?
Old Aug 11, 2010 | 06:58 PM
yes, its for a turbocharged h23a1.
Old Aug 11, 2010 | 07:16 PM
Jdm_Ego's Avatar
looks really good man
Old Aug 12, 2010 | 09:04 AM
thanks but I would like to talk about the throttle body selection instead. If it helps the operating rpm is idle-7,250 rpm. The power level is 400hp/400tq.
Old Aug 12, 2010 | 12:23 PM
GhostAccord's Avatar
If you would rather talk about throttle body selection instead of welding and fabrication. Maybe you should post this in the forced induction forum rather than the welding fab forum.
Old Aug 12, 2010 | 12:31 PM
I believe this is the correct area. If any one was to use either of these units it will involve welding and fabrication. So I would probably reach them here.
Old Aug 12, 2010 | 12:49 PM
Sorry my bad. I just figured that you would get more response from the FI forum guys.
I built these and I have yet to post in this section regarding there function or parts related to them.
I stick to the All Motor section and have gotten lots of info.
Old Aug 14, 2010 | 10:52 AM
they look good but maybe you should have put the runners further down on the stock manifold flange to eliminate some of the turn on the number 1 cylinder.
Old Aug 14, 2010 | 06:12 PM
Thanks
I thought the same thing. Maybe my next set I'll have them equally spaced like they should be.
The No. 1 runner doesn't look quite as bad from the inside. I massaged it a bit to try and straighten it out.
dkrex001
Sep 6, 2006 07:01 PM
AccordSleeperZzZ
Jul 9, 2006 02:41 PM
DohcVtecCrx
Mar 16, 2005 08:22 PM
