throttle body
i've been tryin to find out what size throttle body to put on the sk2 itkm i have for my h22a4, so it fits right on the manifold, and sizes up with my intake, can someone help? I can't find the answer, and limited on time.
Probably cheaper to do it that way as well.
Also unless you running a turbo, bigger isnt always better with throttle bodies. N/A motors function better on less volume intakes vs bigger intake volumes.
There are always exceptions to this rule, but for the most part on stock motors, bigger doesnt mean better
Go with a 68mm its more then enough for an N/A car and will fit fine. Plus if you try to go with a 70 or bigger there is huge price difference. I picked up a 68mm that I plan to install soon and the shop told me this would be my best choice because my motor is N/A. As far as fitment getting a skunk2 tb would proble be the best fit since its goin on sk2 IM.
brand_NOOBian
Mar 31, 2007 04:43 PM
Nextelbuddy
Apr 12, 2004 01:55 PM
Getting a bigger throttle body does that requir getting a bigger intake pipe to fit around the throt
DroppedTegra
Jan 16, 2002 06:58 AM
