Built H22 Swap Many Extras!! Cheap
I have a H22 swap with the following
Assembled by INLINE PRO
Fully built head
CNC Port n Polish
Supertech Valves
Crower springs and retainers
Venom adj cam gears
Type S cams
Golden eagle Intake manifold (mailbox)
RPM 74mm Throttle body
STR fuel rail
Moroso Oil Pan
Cusco LSD
Avid Mount kit for an eg
sitting on a stock block
I also have a sleeved block, crower rods, and cp pistons
So its 2blocks
2999 takes it all
Need to get rid of, best offer takes it
I also have dss level 5 axles look for 900 but will work something out if you get everything
Fully built head
CNC Port n Polish
Supertech Valves
Venom adj cam gears
Type S cams
STR fuel rail
Moroso Oil Pan
Cusco LSD
So its 2blocks
2999 takes it all
BOOSTWERKS
Mid-Atlantic (Sales)
Jul 7, 2010 07:38 AM
