resistor box question
Old Aug 11, 2010 | 12:11 PM
travishoward's Avatar
Default resistor box question
im swapping in an obd1 jdm d15b vtec
i have my d15b2 wired for mpfi already
if i use my obd0 harness, and the obd0 to obd1 jumper harness for the ecu, and switch the wires to use the obd1 dizzy
will i need the resistor box still?
or can i just get rid of it?
Old Aug 11, 2010 | 12:56 PM
D16SiHatch's Avatar
Default Re: resistor box question
if you are still using the obd0 peak/hold injectors then you need it. if saturated obd1/2 injectors then you can delete it.
Old Aug 11, 2010 | 02:57 PM
ill be using the obd1 injectors that come on the d15b...
so i dont need it?
Old Aug 11, 2010 | 03:08 PM
black0hatch's Avatar
no you dont need it. just solder all five wires together.
Old Aug 11, 2010 | 06:00 PM
crx_si-r's Avatar
its cleaner if you just pin the wires that go the resistor box with one with a block off from any 92+ civic or integra
Old Aug 12, 2010 | 05:41 PM
alright, ill do one or th other depends on whats at the junkyard, thanks yall for the help!
ed3jose
Jun 10, 2015 04:29 PM
lilsicsoul
Mar 1, 2009 04:23 AM
SupraRXZ
Feb 3, 2006 02:15 PM
mr. Grind
Aug 15, 2004 12:13 PM
dpine
Jul 14, 2004 06:19 PM
