crv tranny in a wago?
Old Aug 11, 2010 | 12:02 PM
markspan6243's Avatar
Flattery Will Get You Everywhere
Default crv tranny in a wago?
so i was wondering, would you be able to put like a b18c1 with a crv awd tranny into a wagovan?
Old Aug 11, 2010 | 01:14 PM
wheelgarage's Avatar
Default Re: crv tranny in a wago?
If the mounting points, rear output location and drive shaft lenght is the same...why not?
From being a past Wagovan owner, I would like to see it done. You shoud do a test fit....and let us know.
Old Aug 11, 2010 | 01:50 PM
CRXSIPower's Avatar
Im sure you could, would be some work though, DO IT.
Old Aug 11, 2010 | 07:38 PM
dohc4life's Avatar
im in for it let us know what happens
Old Aug 11, 2010 | 08:52 PM
mattliston's Avatar
can? yes its been done
straight bolt in no ods? unlikely. different driveshaft length, b series stuff is heavier duty and might be bigger, etc.
I dont have any links, but its definitely a fun road to go down
Old Aug 11, 2010 | 11:31 PM
dohc4life's Avatar
basically it can be done get the right mount and everything and get the motor and tranny in, make or buy a custom drive shaft to the stock awd setup crv axles for the rear end are not bigger im pretty sure ive reasearched alot about it. and havent seen it done the awd setup for a crv is not meant to be beat on its for a little extra traction not to put power down, ive seen stock awd wagons with beast singles hold up alot better then b20vtec crvs. the rear axles are weak on those unless you could find a good source for bigger axles and rear diff i would get a drive trian conversion for it. im sure theres some one that makes it by now or go b to d converison keep it sinlge.
sorry for the mispelled/grammar im a little buzzed
shenrie
Jan 16, 2007 11:10 AM
tegtyme
Jul 14, 2006 11:31 PM
monalisa overdrive
Sep 4, 2004 03:23 PM
b22del_sol
Feb 3, 2003 06:17 AM
