Sucked in some water in the rain
Old Sep 16, 2002 | 09:22 PM
ZoNe_HKS's Avatar
Default Sucked in some water in the rain
hi those who were in NYC knows.. it was raining yesterday and the day b4.. hard too, and i prob sucked in some water my car feels weird now... idling jumps... and below 3 rpm, the car shakes ALOT and feel no power, what should i do??? the car will be fine after like 10 minz of hard driving.... my friend said i should change my oil, some said i should check my engine compression..... i dunno... imma sure some of you out there have experienced this problem.. please give your input
Old Sep 16, 2002 | 09:33 PM
psychodog's Avatar
Default Re: Sucked in some water in the rain (PDP_HKS)
I would change the oil first just in case there's a buildup of water in the oil pan.
Did you happen to drive your car through standing water or something?
Old Sep 17, 2002 | 10:51 AM
ZoNe_HKS's Avatar
Default Re: Sucked in some water in the rain (psychodog)
no i was very careful... i avoid anywhere theres water... and if i have to go through them... i dont gas.... i just changed the oil today... **** still act the same way... i really think the engine is a goner....
Old Sep 17, 2002 | 11:24 AM
psychodog's Avatar
You might have a different problem then. Usually the AEM will only suck in water if you are in a pretty deep puddle. Alot of my friends here in Vancouver BC (in rains forever here in the winter) have had no problems in the rain.
Oh, and do a search, this topic with some solutions (some better than others) have been discussed thoroughly.
[Modified by psychodog, 8:25 PM 9/17/2002]
Old Sep 17, 2002 | 12:58 PM
prelude1897's Avatar
Naw, your engine isn't gone. If its still running, then your motor is still good. You just have to check some ****. Take out your spark plugs to see if theres any water on them. If there is, then you're going to need to turn the motor by hand so that the water can be pushed out. If your engine light is on, then see what code you're throwing
Old Sep 17, 2002 | 01:19 PM
H23 Power's Avatar
Default Re: Sucked in some water in the rain (prelude1897)
thats not true
my friend sucked in water in his 00 civic...ran for a few weeks, ran weird but still ran decent...then out of nowhere his rod went through the oil pan
Old Sep 17, 2002 | 01:22 PM
ZoNe_HKS's Avatar
yea i have a friend checked out the engine.. he said its fine.. doesnt sound like anything is bent or anything wrong with the internal.. but i do have a backfiring problem with the engine, this happened b4.. but it went away for couple month now.. dunno what brought it back and why is it soo seveal this time.. i will post this under any topic
Old Sep 17, 2002 | 06:21 PM
ELUD THS's Avatar
New User
try checking your spark plugs thats a good start there. if your car hesitates really bad, then you do have water in your engine. hmm you chaged your oil already like i said tyr the plugs to see if thats the case and clean aorund the plug holes to.
2logicl
Feb 21, 2009 01:12 PM
hondacivic1994
Apr 11, 2007 04:33 PM
SkoundrelUSA
24
Jul 17, 2006 09:08 AM
mandelo
Jul 28, 2004 09:15 PM
