TURBO KIT PART OUT!!!
Old Aug 11, 2010 | 03:22 AM
i getz da chewin's Avatar
Default TURBO KIT PART OUT!!!
located in san diego. would prefer local pick up but I might be able to work with you on shipping if you dont mind paying a paypal fee. Everything is OBO & Sold As Is...Ill make a special Deal if you buy the whole kit. Pics on request.
Jet coated Drag log manifold...150obo
3 inch downpipe to straight pipe + wastegate dumptube...SOLD!
(NEW) obd2a > obd1 ECU conversion harness from phearable...SOLD
obd1 b18b1 ECU with Basemap from phearable.net chipped and socketed for tuning. I set the launch control at 5500 I believe and has a CEL shift light. $150obo
air research T3 60/48 off a ford thunderbird. quick spool.....sold
Tial 38mm wastegate with 5psi spring....160obo
aluminum charge piping with couplers and clamps with intercooler (new)...140obo
550cc RC injectors with jumper harnesses so no need to cut and run resistor box/injector plugs...250obo
255 lph fuel pump...Sold
fast turbo vacuum manifold obo
HKS SSQV blow off valve with injen intake pipe with HKS flange...200obo
motorolla 2.5bar map sensor SOLD
moroso oil pan (5 quart)...200obo
Stainless steel oil feed and return...SOLD
autometer boost gauge (NEW without box)...obo
civic half core radiator to fit turbo manifold. Used for 5 miles driving up and down my block.... 80obo
Old Aug 11, 2010 | 03:36 PM
Default Re: TURBO KIT PART OUT!!!
Up búmmmmmmmp
Old Aug 12, 2010 | 07:49 AM
bump
Old Aug 12, 2010 | 08:46 AM
boostedeg302's Avatar
bump for viewing
Old Aug 12, 2010 | 08:47 AM
Pm'd
Old Aug 12, 2010 | 09:00 AM
hotmignacio's Avatar
how much for the whole kit?
Old Aug 12, 2010 | 09:22 AM
Id consider 1600 for everything below. Certain things can be removed to make it cheaper. The whole kit is bolt on.
Jet coated Drag log manifold with 3 inch downpipe to straight pipe + wastegate dumptube + wastegate elbow...350obo
(NEW) obd2a > obd1 ECU conversion harness from phearable...75obo
air research T3 60/48 off a ford thunderbird. quick spool.....PENDING to mazdaturbo10
aluminum charge piping with couplers and clamps with intercooler (new)...200obo
255 lph fuel pump obo
motorolla 2.5bar map sensor obo
Stainless steel oil feed and return...obo
Old Aug 12, 2010 | 01:28 PM
uuppp
Old Aug 14, 2010 | 03:19 PM
uuuuuuuuuuuuuuuuuuuuuuuuuuuup
Old Aug 15, 2010 | 10:14 PM
uuuuuuuuuuuuuuuuuuuuuup boooost up
Old Aug 16, 2010 | 09:21 AM
bumpppppp
Old Aug 16, 2010 | 08:53 PM
mazdaturbo10's Avatar
more pix of turbo??
take 150 for it?
Old Aug 16, 2010 | 10:23 PM
Originally Posted by mazdaturbo10
more pix of turbo??
take 150 for it?
PM'd
Old Aug 16, 2010 | 11:25 PM
turbo pending to mazdaturbo10!!!
Old Aug 17, 2010 | 04:24 PM
bumppp im hungry
Old Aug 17, 2010 | 07:24 PM
bump bump bump
Old Aug 17, 2010 | 10:00 PM
bumppp
Old Aug 17, 2010 | 10:59 PM
ummda9guy's Avatar
how much for the fuel pump?
Old Aug 17, 2010 | 11:09 PM
HOODWORKZ's Avatar
whos intercooler made by? wats the hp rating and dimensions?
Old Aug 18, 2010 | 07:27 AM
sorry sold.
Old Aug 18, 2010 | 10:09 PM
BUMPPPPPP
Old Aug 19, 2010 | 08:05 AM
uuuuuuuuuuuup
Old Aug 19, 2010 | 11:00 AM
F.T.A's Avatar
pmd u
Old Aug 19, 2010 | 11:06 AM
Ohio's Avatar
turbo still available?
Old Aug 19, 2010 | 11:22 AM
Its pending until tomorrow.
