94 Civic Coupe SHell CHEAP! D series SWAP Cheap! D Auto Trans Cheap! Turbo stuff
Old Aug 11, 2010 | 02:17 AM
ZombieBuilt's Avatar
Default 94 Civic Coupe SHell CHEAP! D series SWAP Cheap! D Auto Trans Cheap! Turbo stuff
I got a homie selling a 94 Honda Civic Coupe SHELL for sale.
CLEAN TITLE == - - PINK SLIP IN HAND!!!
Registration paid for until 2011
Exterior -
Black Satin Paint. Teal Engine Bay.
Straight body only a few small normal dings NO DENTS etc.
Red/Clear Taillights
Clear corners
HID kit on headlights 8k I believe
Windows Tinted
Suspension- Stock shocks all around with stock springs
Wheels- 17" black rims with silver lip (i dont know brand) rims are rough shape to be honest but none are bent.
Tires are ok but one does not hold air.
Pinhole somewhere it takes a few days to drop.
Brand new Brakes up front
Car has an upgraded muffler and the exhaust goes almost all the way up its cut about 1ft from where the connection to a header would be. It has no CAT which is why its like that Im sure.
Bad:
Rad support was bent (not that bad) because an idiot Tied a chain around it to tow the car and f*cked it up. So because of that incident the hood latch does not work. So we installed hoodpins and can close the hood. Works great. Old school HotRod hood pins installed. Mr. Gasket.
Car looks clean in and out.
Interior--
Interior is clean.
Power windows and door locks
Front and back seats.
Its all gray and carpet is in good shape.
Dash is all there
No AC
Tweets on doorpanels
No radio
EX Cluster -- ODOMETER -- 157XXX
Car is a Manual Transmission Car
Drop a Motor and Trans in and go! Almost ready to roll
Will need Radiator and engine harness as well as some fuses. Little stuff.
PRICE $1000
I AM ALSO SELLING A D15Vtec COMPLETE SWAP with Trans (b000)
Trans has a slight grind in high Rev 3rd gear shift
(not all the time just sometimes, Just beign honest)
Needs new throwout bearing
Stage 1 Racing clutch (grabs hard!)
It comes with a new timing belt and Water pump installed
axles (1 is brand new)
mounts
Stock intake box
stock header
Comes with dizzy, plug wires and recently changed ngk plugs
Intake manifold complete with injectors sensors ETC
only thing missing is engine harness and ECU.
Price for swap $500
Also have Header for D series
421 design $50
96 y7 Auto Trans $150 with convertor and flexplate.
EG/DC B series Shift linkage $80 comes with short shifter
ALL WIRING from Dash Foward for a ODB0 EF 88-91 $20
Ls oilpan $10
Ls Crank good condition $100
GSR crank good condition $125
od0 Ecu I forgot which one Ill look later $20
Wiper motor assembly for EF Civic both sides $20
d Series rocker Valvetrain for a Vtec Head
(not the springs just the stuff that sits on top of the retainers) $20
D16z6 Valvecover $20
t3/t4 Turbo 50 trim unknown brand (no markings) NOT EGAY! great shape no shaft play, oiling etc. $250
B series XS turbo manifold (original that spawned egay design) braced up and ready for action $60
SRT4 Intercooler, Stock entrances are on the rear not side by side $60
Bar and plate Intercooler I can measure if interested. Good size. $80
94-97 (White) Integra front end. Both Lights Bumper hood and Fenders $150
Tial 38mm Wastegate 7 psi Spring $140
Greddy BOV Type S purple Great condition $120
Integra Black Dashboard- DC . Rough shape has some white paint overspray$40
Used for 5k Manley H beam Rods $250 Perfect shape Better then EAGLE!!!
Used probe forged pistons 9:1 B series 81.5mm Will come with new Rings $200
D16z6 Block machined and notched to accept Eagle H beams $100
Everything is in Antelope Valley CA
If you buy Both car and swap I can work out a package deal Hit me up.
Always interested in trades. LMK what you got.
Currently looking for a b16 VTEC head.
Old Aug 11, 2010 | 02:40 AM
eDdie28's Avatar
Default Re: 94 Civic Coupe SHell CHEAP! D series SWAP Cheap! D Auto Trans Cheap! Turbo stuff
how come the door jams are like captiva blue
Old Aug 11, 2010 | 06:44 AM
95ProjectEJ1's Avatar
BUMP
Old Aug 11, 2010 | 11:22 AM
Car was painted blue at some point.
Old Aug 11, 2010 | 11:44 AM
Black-Ty [EG6]'s Avatar
glws
Old Aug 11, 2010 | 11:46 AM
jdmeg6118's Avatar
Old Aug 11, 2010 | 07:46 PM
ttt
Old Aug 11, 2010 | 09:33 PM
trades welcome
Old Aug 11, 2010 | 11:29 PM
ttt
Old Aug 11, 2010 | 11:30 PM
sii.'s Avatar
trade the slips for the motor?
Old Aug 11, 2010 | 11:32 PM
DO/\/\O's Avatar
ive seen this on craigslist for a while
Old Aug 12, 2010 | 02:07 AM
CrazyFNG's Avatar
Ive seen this in my driveway for awhile
Old Aug 12, 2010 | 10:23 AM
sii.'s Avatar
D:
Old Aug 12, 2010 | 11:22 AM
ttt
thinking about it sii
Old Aug 12, 2010 | 11:13 PM
Take $800 FIRM on the Shell.
Old Aug 13, 2010 | 08:30 AM
ttt
Old Aug 13, 2010 | 09:16 AM
vroomeo's Avatar
by any chance, is ur gsr crank reconditioned?
Old Aug 13, 2010 | 09:28 AM
nope pulled out of the motor at about 50k
Old Aug 13, 2010 | 03:03 PM
ttttttt
Old Aug 14, 2010 | 07:43 AM
tttt
Old Aug 14, 2010 | 10:31 PM
Old Aug 16, 2010 | 01:53 AM
kevs-ej1
Mar 22, 2010 09:34 PM
ToPNoTcHTeChNIk
Mar 10, 2009 01:57 PM
oxSLEEPERxo
Oct 6, 2005 07:21 PM
UltRaH22
May 31, 2004 01:10 PM
