FS TURBO PARTS Progress Sway Bar Coilovers
located in san diego. would prefer local pick up but I might be able to work with you on shipping if you dont mind paying a paypal fee. Everything is OBO & Sold As Is...Ill make a special Deal if you buy the whole kit. Pics on request.
Jet coated Drag log manifold + wastegate elbow....160obo
3 inch downpipe to straight pipe + wastegate dumptube ...SOLD
(NEW) obd2a > obd1 ECU conversion harness from phearable...SOLD
obd1 b18b1 ECU with Basemap from phearable.net chipped and socketed for tuning. I set the launch control at 5500 I believe and has a CEL shift light. $150obo
air research T3 60/48 off a ford thunderbird. quick spool.....200obo
Tial 38mm wastegate with 5psi spring....160obo
aluminum charge piping with couplers and clamps with intercooler (new)...200obo
550cc RC injectors with jumper harnesses so no need to cut and run resistor box/injector plugs...250obo
255 lph fuel pump obo
fast turbo vacuum manifold obo
HKS SSQV blow off valve with injen intake pipe with HKS flange...200obo
motorolla 2.5bar map sensor...sold
moroso oil pan (5 quart)...200obo
Stainless steel oil feed and return...SOLD
autometer boost gauge (NEW)...obo
progress sway bar rear DC2 24mm ...200obo
civic half core radiator to fit turbo manifold. Used for 5 miles driving up and down my block.... 80obo
Ksport coilovers 36way adjustable...used for 2 years work fine....400 + your stock suspension firm
i getz da chewin
Sep 23, 2010 02:12 PM
b00sted4dr
Jun 9, 2005 07:31 PM
Sylverius
Jan 16, 2004 12:47 PM
