Honda Civic (2001 - 2005) Coupe / Sedan / Hybrid (Includes Acura EL)
01 Civic EX overheating
Old Aug 10, 2010 | 07:29 PM
ddockins4010's Avatar
Default 01 Civic EX overheating
I have a 2001 civic ex that overheats at highway speeds. Turning on the heater cools the engine. Have replaced the thermostat but no help. Fans run. There are no apparent leaks. Have burped the system. Radiator is full and collant bottle is at normal level. Any ideas?
Old Aug 11, 2010 | 07:29 AM
EM2abe's Avatar
Default Re: 01 Civic EX overheating
When it starts to overheat, pull off to the side o fthe road and see where the coolant level is, on the resevoir. if its near the top, then you have a rather big problem. This sign is imminant so it make take a few tries to actually see if your coolant is high in the resevoir. Also, try looking through the recent past thread of overheating, in this '01-'05 civic forum. Do some research that way and see if you come up with any luck....
Old Aug 11, 2010 | 08:58 AM
I'll try that. If the coolant reservoir is full, what kind of problem am I looking at? So far I haven't found anything quite like it in the recent threads but I'll keep looking. Thanks
AllenLogue
May 25, 2018 05:00 PM
omerfar23
27
Aug 25, 2013 03:51 PM
mimog3
Jul 21, 2013 07:31 AM
Squad1
10
Oct 18, 2009 07:24 PM
Exitialis
Apr 25, 2009 11:00 PM
