Road Racing / Autocross & Time Attack Road Racing / AUTOX, HPDE, Time Attack
Life was simpler when I didn't believe in sway barz...
Old Aug 10, 2010 | 06:56 PM
RR98ITR's Avatar
Default Life was simpler when I didn't believe in sway barz...
...but I don't not believe in them anymore...
Scott, who so wants to get the rear sway bar done...so he can start on the front...
Old Aug 10, 2010 | 07:35 PM
kristo's Avatar
Loved
Default Re: Life was simpler when I didn't believe in sway barz...
Serious stuff. Very.
Is this a one-diameter-only setup? Custom LCAs?
Roll resistance with this thing should be HUGE, not?
Planning some simular design up front?
Qs, Qs, ...
Old Aug 10, 2010 | 07:38 PM
wannaBjdmca6's Avatar
what wheel/tire specs wil you run?
Old Aug 10, 2010 | 08:33 PM
dirty19's Avatar
Ridin Dirty in Cali
Stop talking to Scott and get it done!
Looks good keep the pics coming.
BTW
I hate sway bars too
Old Aug 10, 2010 | 08:40 PM
civichb20's Avatar
PM Garage
Look nice looks a little small though but your the mad scientist.
Old Aug 11, 2010 | 03:14 AM
chargeR's Avatar
It does look small but look at that motion ratio. Oh my. Arms on the bar look really short too. Interested in more pics .
Old Aug 11, 2010 | 03:29 AM
kelsodeez's Avatar
derp resistant
beefy
Old Aug 11, 2010 | 04:38 AM
Kozy.'s Avatar
a.k.a. Komodo
Interesting stuff Scott, do you have a thread running detailing the work on the rest of your car?
Is that strut rod just a stand in item for the actual damper or are you creating an inboard cantilever system?
Old Aug 11, 2010 | 05:06 AM
chrisdavis6's Avatar
That’s awesome! always love to see this type of grassroots ingenuity.
Wish there were more threads on HT like this. Definitely what I would like to
be doing if I had a work space and was good with the maths!
Would love to see this rest of the car as well
Old Aug 11, 2010 | 05:56 AM
2fast4u831's Avatar
I'm really 2slow
we need more info on this car.
Old Aug 11, 2010 | 06:23 AM
Egezzy's Avatar
Spongebrad Squarepants
more details on the strength of the trash can!
Old Aug 11, 2010 | 07:18 AM
slammed_93_hatch's Avatar
Very nice Scott..
But give us some details on the bar.. it looks very interesting
Old Aug 11, 2010 | 08:26 AM
JamesL's Avatar
Old Aug 11, 2010 | 08:36 AM
2fast4u831's Avatar
I'm really 2slow
most likely a cantilever. those are also big calipers in the rear.
Old Aug 11, 2010 | 09:53 AM
GSRCRXsi's Avatar
Looks like good work. what you are gaining in motion ratio might be lost due to decreased stiffness from a longer arm. Why not extend the swaybar wider and get more of a 90* angle on LCA and swaybar? That way the sway arm will be shorter.
What was the reason for mounting the swaybar like this anyway? With the bar on the subframe yeah you have a risk of tearout, but you can brace it up and you get more stiffness/thickness because the arms are even shorter.
Old Aug 11, 2010 | 10:02 AM
kristo's Avatar
Loved
Old cantilever thread:
EG with Cantilever suspension
Old Aug 11, 2010 | 10:40 AM
solo-x's Avatar
Very nice Scott. If I may...
The reason for the shorter center section and splayed arm ends is likely a tire fitment concern. At any rate, the difference of adding a longer center section and having the bar ends come off at a 90* angle will result in a softer bar rate. The virtual arm length would be unchanged, and with such beefy arm ends the flex in those arm ends is pretty small.
Scott, did you shoot for a bar rate close to the speedway setup you had before? Did you compensate for the massive rate loss you get with the stock attachment to the LCA? That bar looks quite a bit bigger then what I swagged for a bar diameter with a 1:1 motion ratio.
Interested in your plans for the front bar. That stock pretzel is annoying the crap out of me, and at 12lbs, it's doing nothing for the diet the car is on. I'm not as willing to chop up the car as you are though.
Old Aug 11, 2010 | 11:56 AM
GSRCRXsi's Avatar
You're right. I over looked the fact that a longer bar (of same diameter) would be softer.
I still prefer a simpler setup with right angles on the bar and lca. This focuses the force into torsion on the bar rather than the bending moments induced by having a splayed arm (although they are small) I just like the simpler more efficient design. Bringing the bar closer to the lca (like on the subframe) will shorten the arm and make the setup stiffer.
Old Aug 11, 2010 | 03:50 PM
RR98ITR's Avatar
There's not that much to see on the rest of the car. It's pretty unremarkable. There are pics in prior threads of things like my pedal and steering column setups.
NO! That little peice of all-thread isn't a pushrod for a rocker setup! There'd be nothing much to gain with that unless I developed a fetish for a lower/higher/better motion ratio for reasons having to do with dampers and limited wheel displacement which would probably be inapplicable here.
So about the bar. Giant pain in the *** packaging wise. The deletion of the stock rear caliper and giant e-brake protrusion made possible the layout I selected. The mounting pad placement is based on where the existing structure is. I could have run a larger carrier tube for bar in the same location and gotten a more outboard location for the bearings, but I chose not to mostly for philosophical reasons (keep it more bolt on). Just in case you don't know what you're looking at, that last pic shows both the bearing carrier and the mating shoe that goes inside the frame channel. I welded a central boss in the shoe and cut a hole above it in the trunk floor in case I wanted to run a strut to the shock tower if I wanted more vertical stiffness, but my friends who've seen it don't think that's necessary.
The bar is from Speedway Engineering and is 5/8 inch diameter. The bosses I welded into my arms started life as steering couplers from Speedway Motors. There being no standard for splines you need to send a sample boss to SE to get the bar spline cut to mate, which they will do. Arms are at about 45 degrees and then the pickup flange for the pushrod gets mounted at 45 degrees to the arm, so that it swings in a plane and not a cone. The rate of this setup as I calculate it is around 550 ft*lb/degree, or around 25% of my total rear roll stiffness (the percentage recommended by my current chassis engineering guru (ret) (dec)). The stock setup? So hard to calc or measure, the offset mounting and LCA twist factor muddying up the water - double at around 1000 ft*lb/degree?
The rod moves from the inboard forward cranny of the TA at full droop toward the outside coming fearfully close to the hose fitting on the caliper at 2 inches bump. It's a tight fit. A high misalignment rod end is required on the bottom end becase there's alot of angular change in the TA. Isn't that a great hardpoint just waiting to be used?
What else? Ah, the orignal setup. Terrible. But they got the job done, clearing things like exhaust and remote fuel filler piping (deleted on my car). Who cares about motion ratio for springs and bars anyway. But that offset mounting stock had to go, and then you're left with a very very short arm and a very short link, and a need for another hole in the top of the LCA, or a boss on the bottom of the LCA and a Subaru-like horseshoe shaped link - pass on that.
Oh, and the simultaneous engineering and manufacture has been a succession of "oh crap" and "Eah, I can still make that work" - a joy.
Scott, who is in the doldrums between conceptual completion and actual completion...
Old Aug 11, 2010 | 04:40 PM
.:Made in OC:.'s Avatar
Nice stuff. I had a similar design but I never got around to finishing it... Test fitment shots.
Old Aug 11, 2010 | 05:59 PM
GSRCRXsi's Avatar
Do you have 2 sway bars? Lol
Old Aug 11, 2010 | 06:26 PM
The Destroyer's Avatar
Dont let Scott see that pic, he might start thinking beyond outside of the box
Old Aug 12, 2010 | 01:59 AM
You failed to read.
Old Aug 12, 2010 | 05:03 AM
meb58's Avatar
...motion ratios are nice, but sometimes they don't mean much when you add in, or consider, how much friction/spring rate exists in the bushings and dampers etc. Okay, I'm being a cynical!
I had a similar set up on another application. When I recieved the torque tube the splines did not match left to right...bugged the **** out of me. How did you get your manufacturer to produce the plines equally left to right? I fought tooth and nail with my guy... The work around is obviously a slightly longer endlink adjustment on one side but why?
Old Aug 12, 2010 | 06:05 AM
GSRCRXsi's Avatar
Originally Posted by .:Made in OC:.
You failed to read.
I know it's just a mock up. I know he didn't run both at the same time. You failed to understand the joke. It's just a funny picture seeing 2 sways
