Quick help needed. Wideband in HF manifold?
Old Aug 10, 2010 | 06:10 PM
machine4321's Avatar
Default Quick help needed. Wideband in HF manifold?
The bung i tried to weld into my down pipe has some messed up threads . I kinda need the car for work tomorrow before my wife shots me Is it safe to run my wide band in my HF manifold stock location? I dont want to burn it up.
Thanks
Old Aug 10, 2010 | 06:11 PM
wilham320's Avatar
Default Re: Quick help needed. Wideband in HF manifold?
it should be fine for a couple trips, but i would not run it for very long.
Old Aug 10, 2010 | 06:14 PM
Thanks for the quick reply.
I am assumming leaner numbers?
Old Aug 10, 2010 | 06:42 PM
wilham320's Avatar
the number should be the same. unless you have some leaks at the turbo or downpipe.
Old Aug 10, 2010 | 08:04 PM
Thanks again. too late to do a full road tune but its good enough to get me to work and back. I will get another bung tomorrow and try again.
EKSedAndy
Mar 27, 2010 02:16 PM
4drSi
Oct 7, 2007 06:31 PM
SiR HatchAlot
Welding / Fabrication
Feb 22, 2005 05:10 PM
Maddhatcher
Sep 24, 2003 08:41 AM
