Sport-Shift light flashing - no problem with speedometer
Old Sep 16, 2002 | 08:55 PM
papak's Avatar
Default Sport-Shift light flashing - no problem with speedometer
The transmission will not downshift to first. Appears to use third gear only unless you manually downshift, then it goes to second gear. Indicates codes 1,2,5,7,8 & 14 as read on A/T controller. Indicates lock-up solenoids or shift solenoids or PGM-F1 or FAS wire problem. All T/S checks are in tollerance on voltage and resistance........ I do not see how you can get this many indicated problems at-once. There must be a common thread that excapes me.
Please Help with any clues. The last step is to replace the A/T Controller... ANYONE HAVE ONE IN GOOD WORKING CONDITION for sale, or know of a repair facility for them?
[Modified by papak, 3:45 PM 9/17/2002]
Old Sep 18, 2002 | 06:09 PM
papak's Avatar
Default Re: Sport-Shift light flashing - no problem with speedometer (papak)
No responce! I thought only I was stumped. Any thoughts or help is requested.
Old Sep 19, 2002 | 05:14 PM
bill-71SS's Avatar
it is your controller, very common prob.
Old Sep 19, 2002 | 07:23 PM
papak's Avatar
Default Re: Sport-Shift light flashing - no problem with speedometer (bill-71SS)
Thanks for my only reply. I had come to the same opinion. I do not have the necessary test hook to test ECU and A/T while hooked up. That left the lingering worry of the ECU or the FAS wire being at fault due to being un-tested. Trying to find a way to clear them before ordering the A/T unit now. This has been a learning experience due to lack of need tools to test correctly.
Many thanks David
da1lydr1ver
Honda CR-V & Element
Jul 11, 2010 11:24 PM
92honda accord
Oct 26, 2007 02:48 PM
Accordo
Feb 7, 2006 08:01 PM
Mr_Q
Jun 30, 2005 09:32 AM
