Oil pan gasket replacement.
Old Aug 10, 2010 | 01:39 PM
turry89si's Avatar
Default Oil pan gasket replacement.
I was wondering what exactly needs to be done to replace my oil pan's gasket on my d16z6, but without pulling the motor, because I don't have that necessity.But I do have a lift, so I can get under it.
Thanks.
Old Aug 10, 2010 | 04:53 PM
D16SiHatch's Avatar
Default Re: Oil pan gasket replacement.
all you have to do is remove the portion of the exhaust that's in the way and then remove the pan. i forget if the flywheel inspection plate has to come off or not. either way, it's easy peazy
Old Aug 10, 2010 | 06:20 PM
turry89si's Avatar
Oh haha well that will be super easy,cause I don't have any exhaust piping, just header at the moment. Thank you for replying.
Old Aug 10, 2010 | 06:25 PM
B16-CRX's Avatar
Do not pull the engine! It is very easy. Do a search and there are probably a thousand how-to's on it.
Old Aug 11, 2010 | 04:18 AM
BrayzieEF9's Avatar
When I did mine, I just removed the header down pipe(Bottom portion of a 2 piece header) and flywheel inspection plate.Then the oil pan.It's super easy to do, especially with a lift.
Old Aug 11, 2010 | 08:20 AM
EL Vap133's Avatar
Not sure what torque specs are needed for it but if you can find that info make sure to use it or you will get a leak. Good luck!
Old Aug 11, 2010 | 01:39 PM
BrayzieEF9's Avatar
It's 9 ft lbs, in a criss cross pattern. Starting from the center.The drain plug is 33 ft lbs.
Old Aug 11, 2010 | 04:33 PM
EL Vap133's Avatar
Ahhh, good man!
Old Aug 14, 2010 | 08:05 PM
dadriver's Avatar
A nice trick when doing this job....clean oil pan once removed and dry place new gasket on the pan and take sewing thread and thread the string through a few holes and just tie small knots then the gasket will stay in place when putting it back on the engine once you have it up there in place and some bolts in not tight but in, cut and remove thread....
Old Aug 14, 2010 | 10:30 PM
BrayzieEF9's Avatar
or just use a gasket sealant..........
Old Aug 15, 2010 | 06:15 AM
dadriver's Avatar
ur only suppost to put honda bond on a couple of spots so it wont leak
Old Aug 15, 2010 | 07:59 AM
BrayzieEF9's Avatar
yeah and it will hold it in place
Old Aug 15, 2010 | 08:38 AM
JDMEF's Avatar
just lift, and since you dont have an exhaust you could prolly just unbolt it from there.. and dont forget when you tighten it up to get the torque specs for it.. there on the owners manual thing
Old Aug 15, 2010 | 09:25 AM
BrayzieEF9's Avatar
I already gave the OP, the torque specs.
Dorkenheimer
20
Sep 16, 2015 09:43 PM
hYbRid_Eg6
Feb 12, 2012 06:14 PM
SleeperGSR
Jun 23, 2011 05:08 AM
xTomei
13
Dec 11, 2010 07:38 AM
drumsy
Feb 6, 2002 12:18 AM
