Finishing Economy Hatch
I put a d15b6(88 hf) into a 1991 si hatch. im trying to make a economy 4 seater with options like sunroof, etc. everything is wired up except the plug in the evap black box. red, green, and two black and yellow. i was told to wire them like this...
(the 2 black/yellow wires are both power (one for EGR solenoid and one for purge solenoid) and connect together inside the harness and also connect to other black/yellow wires which ultimately end up at Fuse #14 in the under dash fuse box
the red wire is the signal for the EGR solenoid on the firewall and goes to ECU pin A10
the green wire is the signal for the purge cut-off solenoid on the firewall and goes to ECU pin A6)
is there something im missing?
can i just block off the egr?
