Is my transmission shot?
i have a 98 acura cl with 170k miles on it. the tranny was stuck in 1st gear, and so we did a fluid drain and the fluid smelt burnt. i put new fluid in it, and was driving like a dream for like 2 days, and then is shifting horribly, seems like it is slipping, and as soon as i let off the gas it downshifts.
Exactly what mine does and i have a 98 Accord v6 with 160xxx. Just keep changing the fluid and make sure its fresh. I am concidering switching to Castrol ATF High Mileage but no ones has any opinions on this..
the first time i drained it the fluid was dark brown. i just refilled it with fluid and it was driving fine, and then started shifting horribly. i drained that fluid and filled it back up, drove it around the block a few times, and drained and filled it again. then it was driving fine until the car warmed up pretty much...
one thing i noticed was that the auto tranny was pressurized. like i went to go check the fluid after it was shifting bad, and the dip stick comes out with a loud pop and a huge woosh of air. any thoughts?
well assuming it is an auto, mabey you could invest in some more durable than stock baskets(etc) for better shifting/performance
but then again, i do not know much about autos. hope this helps
sadakoyamahonda
Dec 2, 2018 09:42 AM
