16" 4x100 steelies?
I'm looking to pick up a set of 4x100 16" steel wheels for my ED hatch. Does anyone possibly know of a car that had them OEM? I'm doing a little rust repair and Blacking out My beater hatch, and won't even proceed in this project if these aren't available.
Diamond racing wheels. I'm in the same boat right now and that's all I've found so far.
http://www.diamondracingwheels.com/
Only problems I've found are the obvious, steels wheels are more likely to bend, but they can be bent back. Also they're heavy, but not BAD heavy.
Since they're only steelies, and you're doing this for an old Civic that needs small tires, I'd suggest going no larger than 15", and getting 195/50-15 tires. The wheels will be cheaper and so will the tires. You can get 15" 4x100 steelies from some 2001-2005 Civics.
How about 16" alum 4 lug wheels off an 97 acura, I have a set I took off my CL they are six spoke with the large center caps that cover the lugs.
They are straight and not curbed, I just did not like the look of the wheel on the car, I guess they could use painting but that is no big deal.
Pm me if your interested....B Guz
All of the Mazda models which came with a 4x100 lug pattern had a 54 mm center bore. That means none of the wheels will fit onto a Honda hub with its 56 mm center, unless you drill them out. That's a lot of trouble to go to for cheap steelies. Also, the models that came with a 4x100 lug pattern are their smaller and older models (Miata/MX-5, '01 and older Protoge, '96 and older MX-3/323) which I doubt came with wheels as large as 16".
The only Suzuki model with a 4x100 bolt pattern was the Esteem, which came with 13" wheels.
