rota slipstreams key lock....
Old Aug 9, 2010 | 06:29 PM
ultima4300's Avatar
Default rota slipstreams key lock....
....my rota slip stream wheel lock key broke and i dont know where to find another one if anyone can help it would be much appreciated
Old Aug 9, 2010 | 07:00 PM
Cortez_h's Avatar
Default Re: rota slipstreams key lock....
Take it your referring to your lug nuts? What brand do you have?
Old Aug 10, 2010 | 12:22 AM
thumper64's Avatar
If you know the brand, order one from that company. Or shops will do it or you could weld a bolt to the nut...
Old Aug 10, 2010 | 12:47 AM
EG9_808's Avatar
Ouch this happened to me few years back, had to literally make a good slit good enough to have grip and keep pounding away till it came loose.
Old Aug 10, 2010 | 01:59 AM
Nichelson_Performance's Avatar
that sux, happened to me before too, its a real pain to get the lugs off especially since the holes in aftermarket wheels are usually sunk down into the face of the wheel so normal lug nut removal tools won't work
i ended up buying another set of tuner lugs that used the internal style key and had to grind down the key itself just to get them off
now i use a regular style hex lug nut instead of the tuner lock style
eg64u
Jun 18, 2004 06:01 PM
devonic
Apr 14, 2003 05:20 PM
Ceeveek
Jun 20, 2002 11:35 AM
Type-ARR
Sep 17, 2001 11:50 AM
