Suspension & Brakes Theory, alignment, spring rates....
brake pedel clicking noise and have to push in pedel far to start braking
Old Aug 9, 2010 | 06:00 PM
swizz977's Avatar
Default brake pedel clicking noise and have to push in pedel far to start braking
ok so whenever i press the brake pedel about half way down it makes a loud cracking crunching sound and i can feel it too its really annoying what is that?
and also when i push the break pedel down it only starts to brake about halfway down.. is there anyway i can make it so it starts braking when the pedel is higher cuz it brakes when the pedel is so low..
Old Aug 10, 2010 | 06:46 AM
swizz977's Avatar
Default Re: brake pedel clicking noise and have to push in pedel far to start braking
bumppppppppp
Old Aug 10, 2010 | 09:40 AM
alphalanos's Avatar
Look under the dash. check pedal operation. Check the brake system for leaks and bleed the brakes correctly. If its making noise during the pedal stroke I would look at master cyl, booster, and the pivot/bolts on the pedal assembly.
swizz977
Mar 10, 2014 03:48 PM
04es1civic
Suspension & Brakes
Aug 20, 2011 12:04 AM
TonyBlaz
Feb 3, 2009 11:13 AM
traxxasx
Jan 11, 2008 06:21 PM
lv6l
Jan 4, 2005 11:42 AM
