Garage sale
99 gsr power steering reservoir and bracket $20
gsr alternator pulley $15
jrsc 6pst belts one goodyear gatorback and one poly cog $12 for both excellent condition.
3" v band gaskets $7 each
1 new redrilled rsx type s 11.8" rotor for 4x100 s2000 brake swap. $40
New front pair ebd redstuff brake pads for acura RL 2005-09 4 piston calipers $90 shipped usps priority
92-93 integra New clutch throw out bearing $30 shipped
jrsc boost relay $15
oem acura oil cap $10
front upper control arms (missing dust boots/ swapped on sk2 ball joints)and rear factory camber arm. $40
excellent condition oem gsr wing in FBP $30
SOLD stuff
oem radio din tray SOLD
Modified oem strut bar to 3pt SOLD
LNIB Personal Blitz steering wheel 330mm SOLD
Refinished wrinkle finish B series valve cover with oil cap. SOLD
LEGEND BRAKES SOLD
99gsr power steering pump sold
99 dc2 leather wrapped steering wheel $60 mint sold
OEM 99 GSR 240 Injectors and o rings $50 (only 19k on it) sold
BFGoodrich G-Force T/A KDW 2 205-40-16 70-80% tread SOLD to DB
low mileage gsr brake calipers pads and shims with brembo rotors. perfect for a brake swap. Calipers SOLD
Rotors sold
Still within spec 21mm like new.
OEM GSR CLUTCH/ FLYWHEEL/ Alignment tool with 25k miles on it SOLD
water injection kit 100psi pump traded
Stock jrsc 6psi pulley sold
SFI spec nomex racing gloves New size Large
oem gsr throttlebody no sensors SOLD
kosei center caps $20 sold
Used 99 gsr diff
2007 335i center rear view mirror
sold
JRSC IDLER PULLEY SOLD
99 oem gsr shifter SOLD
OPEN TO TRADES
located in santa monica
SOLD stuff
LEGEND BRAKES SOLD
Rotors sold
Used 99 gsr diff
sold
OPEN TO TRADES
Was that gsr shifter re-welded? if not I'll take it, what's your paypal? Please ship paypal fate rate 2-3 day priority simply because I need it by Friday. I will add an extra 5 for that. I'm in IE so.cal.
