b16a civic throttle check engine light
Old Aug 9, 2010 | 11:32 AM
jakku's Avatar
Default b16a civic throttle check engine light
Hey all i trying to figure out what is wrong with my Civic, hoping someone can help me. I have a 93 civic hatch with b16a motor. The problem is when it idles its around 1750-2500 rpms and when driving it will not go over 4000 in any gear. and if it hits 4000 if pops over and over kind of like its hitting a rev limiter. i have been told it could be solenoids, o2 sensor, distributor, tps, or jsut simple oil change for pressure. If somone could point me in the right direction i would be forever thankful.
Old Aug 9, 2010 | 11:41 AM
Former User's Avatar
Default Re: b16a civic throttle check engine light
Have you pulled the CEL codes?
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/how-pull-cel-d4-srs-abs-codes-code-lists-1901557/
Old Aug 9, 2010 | 11:44 AM
jakku's Avatar
i shall go do that now
Old Aug 9, 2010 | 12:49 PM
jakku's Avatar
tried it with the paper clip method and a few other wires. nothing seems to work. the light just stay on normal when i turn it in the ON position.
this is right correct?
Old Aug 9, 2010 | 12:54 PM
If you remove the wire/paperclip from the service connector and then turn the key to ON(II), does the CEL now turn on and then off after 2 seconds?
Old Aug 10, 2010 | 01:59 AM
jakku's Avatar
by ON(II) do u mean starting the engine up? when i have the car in on position (where the key would sit when car is running after startup) it stays on with the wire in. do u want me to remove the wire in this stage and then put the key forward as if i was to start the engine. or pull the wire when the car is not on at all. If you mean On2 by the position keys sit when the engine is running then thats the only time the light is on it wont come on in the position before that.
basically first position is sticking the keys in. 2nd click forward is the radio, 3rd click start up the air and such and the CEL comes on 4th would be engine start up.
Old Aug 10, 2010 | 06:21 AM
No. Just ON(II) without starting the engine.
With the key in OFF/Lock (0), remove the jumper wire from the connector. Now turn the key to ON(II) without starting the engine. Does the CEL turn on and then off after 2 seconds?
By convention, the four key positions on the ignition switch are:
Old Aug 10, 2010 | 09:47 AM
jakku's Avatar
k i did that and the CEL stays on doesnt blink or turn off.
Old Aug 10, 2010 | 10:54 AM
You have CEL code 0, which is when the CEL remains on steady both with and without the service connector jumped. If the engine starts and runs, then code 0 indicates that there is a short in either the service connector or CEL circuit or the ECU is bad. You obviously would check for a wire short first.
Old Aug 10, 2010 | 12:14 PM
jakku's Avatar
would this cause the problem with the throttle though or would that be something else?
Old Aug 10, 2010 | 12:26 PM
Not sure. It may help if you give more information about the Civic, the engine swap, and the ECU and wire harnesses used.
Old Aug 10, 2010 | 01:15 PM
jakku's Avatar
93 civic si body b16ablock rebuilt all internals b16a tranny limited slip differential stage 2 clutch light weight flywheel dc dual bend short throw typeR head cams everything oversized throttle body intake manifold injectors fuel pressure gauge plugs wires 4 to1 headers full exhaust
Old Aug 29, 2010 | 10:48 PM
jakku's Avatar
ok im gonna replace the ECU tomorrow if thats the only suggestion
Old May 2, 2012 | 08:29 AM
mnsnomaneg's Avatar
did you check for wire shorts first
Old Jan 24, 2013 | 05:14 PM
Mike Makovsky's Avatar
Can you share with me what your issue was ... with the Civic not going over 4000 RPMs? I have a stock 2000 ex and it does the same thing every once in a while. I had it to a mechanic who said he replaced some sensor that was burned out but I don't know if that was the cause of it not going above 4000 MPH or the check engine light but every once in a while the light comes on and it will not go above 4000 MPH in any gear, then sometimes it will work just fine even though the light will still be on and then sometimes the light will not be on. I am not a motor head but I do change the oil and other maintenance stuff, so I can hopefully fix this but will need some directions. I appreciate any advice you can provide.
SupaHondaCRX
Oct 8, 2009 10:10 AM
crapple67
Feb 27, 2007 01:22 PM
98 coupedelux
Nov 13, 2004 09:41 AM
MADEINIRAQ
Jul 26, 2002 08:55 AM
johnlsturbo
Jul 20, 2002 12:23 PM
