fuel pump relay?
I need to replace a relay that is Honda part # 39794-S5A-003, on an 02 civic lx.
Although, I have no idea where it is! I talked to someone from Honda on the phone and he said it was in the engine bay, but I'm not sure as I don't see anything.
Any help would be appreciated.
Sorry for grave-digging, but I'm stuck!
I am trying to replace the fuel pump relay (Beck/Arnley Relay 12V 90080-87009 156700-0930) on my friend's 2005 Honda Civic Hybrid 1.3l.
I know it's supposed to be behind the glovebox, but the layout does not look like any photo or diagram I have seen of that area. Instead of four relays in a row with the blue FP relay on the left like 口口口口, I have four relays in a square like 田 . None of these are blue, and all have four pins instead of the five pins on the part I'm looking at. I have checked the other three(?!?!) fuse/relay boxes on the car, and found ONE similar relay under the hood with the same pin pattern, but a different size and numbered 156700-1200 instead of -0930. It was labeled with an engine icon.
I was hoping this would be an easy fix/rule-out for his intermittent hot starting problem...
berlido1208
Honda Civic (2001 - 2005)
Apr 10, 2013 11:08 PM
solofthesouth
Apr 15, 2006 06:32 AM
