90-93 Integra front and rear brakes WITH ABS
Old Aug 8, 2010 | 10:40 PM
Fo-Do Fanatic's Avatar
Default 90-93 Integra front and rear brakes WITH ABS
My buddy called me up telling me he is going to scrap his DA Integra and I could have anything off of it. I've already pulled off the front brakes and I'm going back tomorrow to snag up the rear discs, prop valve, e-brake cable and possibly the 1"(in) brake master and booster. Which leads me up to my question....
I've been told that I can't use the 1" brake master cylinder on my car, but I figure if I get the brake booster with it as well I should be just fine, right? Or would it be best to go find the 15/16" brake master and booster instead?
Thanks you mother EF'ers
Old Aug 9, 2010 | 12:26 AM
DCRB's Avatar
Default Re: 90-93 Integra front and rear brakes WITH ABS
da's only came with 15/16ths m/c?? did he change it? if so i'm jealous. get the bb to match the master cylinder. i have a 9" bb with a 15/16ths brake booster in my hatch, and with stock front brakes, da rear discs, 40/40 prop valves and ss brake lines it stops quick and firm.
Old Aug 9, 2010 | 02:03 AM
Ohhh, well sweet. Looks like I'll be all good then
Old Aug 9, 2010 | 02:21 AM
DCRB's Avatar
well i don't think you can swap over the abs pump and all that (maybe you can?) but my rear DA trailing arms are abs arms but i just removed all the sensors and they work the same either way.
Old Aug 9, 2010 | 02:35 AM
I'm not going to run any of the ABS stuff. It'd be a complete waste of time lol. And a lot more stuff to put in an already cluttered engine bay. I already took all the ABS bullshit off the front and I'll do teh same on the rear. Does the ABS brake master cylinder have extra lines running out of it? Or is it the same as the Non-ABS?
classic69
28
Jan 8, 2025 08:12 AM
Fo-Do Fanatic
15
Aug 16, 2010 02:46 PM
KBG Indey
Nov 20, 2006 12:50 PM
stareatsun
Sep 28, 2004 05:25 PM
