LS swap IAT sensor code
91 LS swap in 91 base model hatch....
Is the IAT plug from the DPI harness the green plug back where the old DPI stuff used to be, or is it the longer pigtail white plug with an orange and black wire?
Got everything else fine just IAT code and not sure which plug to use, green plug will need wires extended and i dont wanna go through that trouble if its not the correct plug. those are the only 2 left over that are questionable as to where one might go.
