Did anyone try Throttle Body/Intake Manifold Coolant Bypass??
I read on this website and there are a page that show to do this, did anyone try it yet? Go here to check it out[URLhttp://homepages.paradise.net.nz/asmsbm/tb_bypass.htm[/URL]
i think i basically tried this except what i did is foudn out i had a vacuum leak
so what we did was we sealed off those three funkny holes on the fast IAC valve
you know that circle, oval and rectangular holes? with rubber, so no coolant gets thru which made my motor stop idling so wickedly high and crazy like
[Modified by pkek, 12:20 AM 9/17/2002]
I tried it with my sohc vtec. Did not make a noticeable difference and caused an erratic idle when the car was cold. Not worth it in my opinion. If you're looking for every little bit of power at the track, go for it. For the street, don't bother
I did it, no biggie. The temp of the intake manifold is a little cooler but on the dyno we noticed no difference so....... and I tried it while making 300+whp and the temp outside was damn hott and humid.
I did it on my JRSC hybrid and it idles just fine. I have no real observations on wheather or not it did anything except make the plumbing a litte easier.
Mike
Mike
so what your saying is plug off all the hoses coming from IAC Valve on back of the intake manifold and the other downward curved hose coming off the intake manifold?
freezing in cold climates, Honda engineers decided to run coolant through it.
Bypassing this plumbing will reduce your intake air temperatures and increase air
density, but if you live in a cold climate, you're asking for trouble. Frozen
throttles aren't pretty!
I tried it, no difference on the dyno. I even installed a ball valve to aloow different amounts of coolant flow from full flow to nothing.
HP readings never changed.
Only thing that changed was the idle quailty. I'm still running it the wat Honda designed it. Running quite well I might add.
this is NOT a 85+ TPI, LT1, or LSI motor.
Yes the bypass mod works GREAT on the engnes I just listed.
I also play with a 86 TA 5.0L TPI peanut cam F Body.
When my cold idle valve on my 95 GSR throttle body went bad, I figured this out on my own. The car idles funny after heat soaking for a while, but it still runs. Looking to get a ITR throttle body later.
Shawn
Shawn
nothing_shocking
10
Feb 23, 2010 09:08 PM
b16hybrid2
Jun 10, 2003 05:46 AM
