94 civic with LS swap issues :/
Old Aug 8, 2010 | 03:52 PM
upstateNY's Avatar
Default 94 civic with LS swap issues :/
ok so i just swapped in a 96 b18b1 into my 94 civic ex. everything is good except one sensor on top of the intake manifold an not sure where or how to hook it up. thanks for any help
THIS ONE
also Im i able to eliminate the evap canister, as u can see from one picture i have one line that doesn't hook up to the new motor? now sure where that would go either. thanks again
Old Aug 8, 2010 | 07:29 PM
upstateNY's Avatar
Default Re: 94 civic with LS swap issues :/
no help lol... any ideas of what the sensor is called? or does?
Old Aug 8, 2010 | 07:41 PM
goldpearleg6's Avatar
since your obd1 you dont need that sensor
Old Aug 8, 2010 | 07:43 PM
apexi_rsx's Avatar
its a evap purge valve solenoid for charcol canister as he said if ur obd1 u dont need it
Old Aug 8, 2010 | 07:46 PM
upstateNY's Avatar
so can i remove it and cap it off or just cap off the plug? thanks thats kinda what i figured from searching but wanted to make sure.
1QwIkEf
Nov 19, 2009 03:53 PM
abusedvtec
Mar 27, 2008 06:24 PM
HATCH92GSR
Nov 18, 2005 07:33 PM
