95 civic dx starting problems. sometimes start sometimes no?
Old Aug 8, 2010 | 12:34 PM
TrackRat's Avatar
Default 95 civic dx starting problems. sometimes start sometimes no?
As the title says i have a 95 civic dx 5 spd and just recently put it back on the road after sitting for quite sometime. I drove it for two days then i parked it last night for about 4 hrs. got in and it would crank but not fire until i kept cranking on it and pumping the gas.
so i get it home. park it for the night. Wake up the this morning and boom crank but no fire.
i checked the plug wires and i have spark
i sprayed starting fluid into the throttle body and it fired.
i hear the fuel pump kick on
what now?
after about 5 min of trying to crank it started but rough cutoff once then started. now it starts fine but im sure it i let it sit for a few hrs it will not start again. im confused to say the least
ideas? thanks
-brian
Old Aug 8, 2010 | 01:11 PM
Former User's Avatar
Default Re: 95 civic dx starting problems. sometimes start sometimes no?
Any CEL codes?
You may want to measure the fuel pressure and replace the fuel filter.
Old Aug 8, 2010 | 01:28 PM
TrackRat's Avatar
no cel codes. i just went and picked up a new fuel filter as i do not recall ever replacing it. I hope this is the fix. i'll let you know
ps i believe you helped me fix my parking bulb issue. just wanted to pass along a big thank you. You are very helpful
Notorious_76
13
Oct 8, 2012 04:38 PM
RULEMKR
Feb 28, 2012 07:40 PM
Orangeciv
Nov 18, 2009 06:43 AM
dookeye
12
Oct 24, 2009 06:16 PM
