Question On Stage 1 Skunk2 Ver. 3 Cams
Old Aug 8, 2010 | 10:03 AM
EduardoDC5's Avatar
Default Question On Stage 1 Skunk2 Ver. 3 Cams
Ok so I went to a shop and they told me in order to put stage 1's i need new valve springs, but i thought stage 1's you can just bolt right on to your stock valve train? any help on this? I need opinions and advice because it sounds like bull to me, that's the first time i have heard that the last i remember stage 1's can just bolt right on to your stock head.
Old Aug 8, 2010 | 11:28 AM
nahonda04's Avatar
Surje.motorsports
Default Re: Question On Stage 1 Skunk2 Ver. 3 Cams
stage 1 cams you will be fine with stock valvetrain but if you upgrade to anything above stage 1 you will need valvetrain kit
Old Aug 8, 2010 | 05:57 PM
cloumep3's Avatar
Like what nahonda04 said, you don't need valvetrain with stage1 cams, I say it's b/s.
Old Aug 9, 2010 | 02:11 PM
EduardoDC5's Avatar
Yeah that's what I said thanks for the advice. Anyone running stage 1's? I want some feedback on these
Old Aug 9, 2010 | 09:15 PM
nahonda04's Avatar
Surje.motorsports
ITR cams are where its at...i paid 200 for mine
Old Aug 11, 2010 | 07:30 AM
EvaUnit01's Avatar
stg1 cams are great for spirited driving, I would compare the specs for the ITR vs the skunk2 cams and see where the gains are. Putting in TSX cams are good as well, not sure the year, would have to research that one.
Old Aug 11, 2010 | 07:38 AM
nahonda04's Avatar
Surje.motorsports
i thought you couldnt use k24 cams in a k20 head? i beleive ITR cams are some where around 262 degrees of lift
Old Aug 21, 2010 | 10:23 AM
ROCKSTAR RX8's Avatar
don't bother with the stage ones.. you don't get a lot more gain compare to ITR cams.. may as well save a bit more $$ go with stage II (that's what i did), then again since the engine head is out you may as well change the valvetrain.. you won't notice too much power gain on the Stage 1s.
Fresno_NSX
Apr 1, 2005 09:46 PM
codeh22a4
Sep 21, 2004 02:27 PM
HARI.
Sep 19, 2004 09:49 PM
jdm pwr
Aug 30, 2004 08:07 PM
riceball777
Oct 19, 2003 09:53 PM
