New suspension: Is the front riding too high?
Hey guys just got done with my new suspension. I went with koni yellow shocks and h&r race springs. Also is the front suppose to sit that high the bumpstops are cut in half all around.
Before
After
As you can see the front sits higher than the back any idea of whats going on.
Before
After
Please make your thread titles subject specific:
https://honda-tech.com/forums/honda-civic-del-sol-1992-2000-1/threads-must-summarize-technical-problem-title-list-car-details-first-post-2809571/
For example, you should mention in the title about the front suspension riding too high. I edited the title for you.
it's called reverse rake and if you got adj. coilovers/shocks just even it out either raise the rear or lower the front... my ej1 with eibach springs has more reverse rake than that so guess your lucky lol
im positive the springs are not on backwards the rears have an R and the front have an F. Any other ideas of wats going on i still have a lower perch setting i can move the front but im affraid im going to be too low for a DD.
do you have a pro-kit or sportline?
the pro-kit lowers the car almost .25" lower up front vs. the rear.
Anybody else have any ideas I'm going to take of my front wheels and take some pictures to show you guys and see if you can tell if anything is wrong.
Then drop the front, it's only like a 25mm difference, so like half inch higher or lower
Personaly id raise the back, the front looks perfect. However you can always try each drop the front/raise the back, it will just be a little time consuming.
i vote for raising the rear perch too; i'd be willing to bet ~1.5" would be ideal, which is what the front looks to be in the later pictures. the intial pictures are either strange from the springs not yet settling or the weight transfer of being parked on an incline...or something. but the later pictures apparently show the current stance.
the rear is entirely too low to offer the best handling, regardless of the front.
Not doing so can and will tear up the bushings.
