NJ 08 CIVIC SI FPB RL BRAKES Hondata!
Up for sale is my 2008 Honda Civic Si Coupe in Fuji Blue Pearl 43,600 Miles on the odometer. This is the only civic i have come across with a custom Acura RL caliper modification rotors/mounting was sold by FASTBRAKES but didnt exactly bolt up alot of fabbing was required and the kit was discounted after i purchased to the complication but they have been on my for roughly 15k miles and i have had ZERO problems with em and incredible stoping power and that OEM Bling! I do not have any service records for the car due to the fact i work for a Hyundai Dealership in north new jersey and i performed all maintenance Spark plugs (@ 33,000), air filter (@30,000 K&N cone for the intake), trans fluid (every 12,000 miles) , coolant flush (@ 30,000). The SI was tuned @ Evans-Tuning In January made 211HP [while having a 60mm apexi N1 on the Si now it has a 70mm Invidia Q300].
Any questions Just email me Evalk@optonline.net and i will respond promptly.(This is my second Si i also had a 2007 Civic Si Sedan) , Just time to move on to a Genesis Coupe (i work for hyundai motor america)
only bad part about the car is that it was hit while stopped but its only paint missing on the rear bumper as seen in the pics.
This car has never seen any track time by the way
Asking 16,000$ Located in North New Jersey I have Title in hand
VIN: 2HGFG21588H702698
Ext:
Yellow fog Lights with PIAA Yellow bulbs
Front JDM Honda badge
Rear JDM honda badge
8000k HID Headlight [Low Beam]
3500k bulbs [High Beam]
1/2" Hood Spacer
Reverse Light Tint (red)
Painted Red Calipers (rear)
20% Tint All Around
Suspension/Brakes:
Eibach Pro-Kit Springs
Progressive 22mm Rear Sway Bar
Redshift Sway Bar Brackets
Acura RL Calipers + 12.8" 350z Rotors + MountingBrackets
Wheel Spacers 15mm + Lugs (Front)
Wheels:
17x7.5 RSX 2004 A Spec Wheels (Painted Gunmetal)
215/45/17 Dunlop star spec z1 Tires
Int:
White Led Dome Lights
Steering Wheel Emblem Red
Type R Key Cover
Blox 490 Gram Shift **** Blue
Performance:
K&N Typhoon SRI
DC Sports Race Header
Invidia Q300 [70MM]
Ingalls Engine torque dampener
Comptech Short Throw Shifter
Hondata Flash Pro
P2R Throttle Body Spacer w/ [2 Gaskets]
Upper Radatior Hose Napa #7777
Spark Plugs OEM (33k Miles)
only bad part about the car is that it was hit while stopped but its only paint missing on the rear bumper as seen in the pics. This car has never seen any track time by the way
Ext:
1/2" Hood Spacer
20% Tint All Around
Suspension/Brakes:
Wheels:
Int:
Type R Key Cover
Performance:
K&N Typhoon SRI
Invidia Q300 [70MM]
Hondata Flash Pro
