89 civic - please recommend head gasket
Old Aug 8, 2010 | 04:55 AM
craftech's Avatar
Default 89 civic - please recommend head gasket
Bubbles in coolant, overheating. 320,000 miles.
Would like to be able to replace head gasket without having to get the head milled. If that's a really bad idea, please let me know.
I would like to know if the FelPro gaskets are OK or should I look at something else. Here are the choices from Rock Auto:
1989 HONDA CIVIC DX Cylinder Head Gasket
Are "Head Shims" required if I must get the head milled?
1989 HONDA CIVIC DX Cylinder Head Spacer Shim
Thanks for the help:
John
Old Aug 8, 2010 | 09:35 AM
94EG8's Avatar
Seagull Management
Default Re: 89 civic - please recommend head gasket
If its been overheated the engine is probably toast. I can pretty well guarantee you that its going to burn oil and the headgasket will fail again prematurely. Pick up a low mileage JDM replacement engine and save yourself a huge headache.
Vtec04
Engine Machining & Assembly
11
Oct 31, 2017 09:26 AM
LSteggyguy
May 29, 2014 09:49 PM
E-AH driver
Classic Hondas
Jan 23, 2012 03:53 AM
craftech
Aug 8, 2010 02:46 PM
filetofit
Aug 13, 2002 08:49 PM
