Lucas 1200cc, AEM Injector Driver, AEM 1052, + more
Old Aug 8, 2010 | 02:53 AM
A51_RPS13's Avatar
Default Lucas 1200cc, AEM Injector Driver, AEM 1052, + more
More added 8/7:
1. Lucas 1200cc Injectors: $250 SHIPPED FIRM
Used for 7000 miles/8 months. These are in perfect condition and work exceptionally well. I went with different injectors so these need to go.
2. AEM 10 Channel Injector Driver: $250 SHIPPED FIRM
Used for the same 7000 miles/8 months. Works flawlessly and would also be GREAT for someone who would like to maybe go with a stepped injection system. Even a E85 setup, running the 1200cc injectors as primaries and 700cc+ injectors as secondaries would allow you to switch back and forth between pump gas and E85. At the moment, there aren't enough E85 stations around so there is not point for me to keep the current setup. Not pictured is the positive plug for the driver. It will be included. It is currently still in the car but will be out by Saturday. Everything is all pinned and ready to go with the injector setup.
3. AEM Injector Driver and Lucas 1200cc Injectors: $450 SHIPPED FIRM
4. Blox Intake Manifold Gasket: $30 SHIPPED
Great for both NA and Turbo. Used but in great condition. No pics at this time.
5. Blox 68mm Cast Throttle Body: $110 SHIPPED FIRM
Great condition. I replaced my SoS throttle body with this one. Not only do you not have the sticky throttle which occurs with billet throttle bodies, but everything functions and looks just like stock. Included is a OEM TPS sensor but does not include a MAP sensor. I made a block off plate for the MAP sensor (perfect for FI guys who are using a GM 3 Bar). This one is 68mm all the way through, unlike the SoS TB. Moved on to a 80mm throttle body on my AFI intake manifold. Also includes throttle body gasket.
6. Project Kics R26 Neo-Chrome Lug Nuts w/ locks & key: $160 SHIPPED FIRM
Great condition. Don't have the 17mm extension that normally comes with it. I lost it somewhere. As you can see, Their in the packaging of the R40's which I'm now using.
6. AEM EMS 1052 (non-UEGO): $950 SHIPPED FIRM
Great condition unit which I've had since I've been turbo. I went with a Series II for the upgraded datalogging and the USB+RS232 cables for my AIM dash. This EMS has been opened and has 2 wires coming out for my AIM dash. This would be perfect for anyone who wants to get a AIM MXL dash as this would work perfectly for you (I can enable everything to work for you). Other than that, it is in perfect condition and I've never had any problems. It will not come with my tuned map, but a standard AP1 map. I will not include a tuned map unless your willing to pay for 1/2 of my tuning bill! It probably wouldn't work for your setup as well anyway. I'm currently holding onto it until I get my Series II in and running correctly (which should be on Saturday 8/7). Until then this will be on hold until I edit the post. You can send me a PM and I will give it to the first person who PM's me for my asking price.
Old Aug 11, 2010 | 02:36 AM
A51_RPS13's Avatar
Default Re: Lucas 1200cc, AEM Injector Driver, AEM 1052, + more
Bump!
Old Aug 17, 2010 | 06:12 PM
A51_RPS13's Avatar
Bump!
t66crx
Apr 7, 2008 03:48 PM
underpressure02
Feb 1, 2006 03:27 PM
