Need temporary fix for cracked radiator
Old Sep 16, 2002 | 06:35 PM
AGen2integra's Avatar
Default Need temporary fix for cracked radiator
I have a small crack on the top of my radiator where the mounting nipple is. Can I use JB Weld or anything to keep it from leaking until I get my new rad from C&R. Any ideas needed!!!! Evan
Old Sep 16, 2002 | 06:59 PM
cbaracing's Avatar
Default Re: Need temporary fix for cracked radiator (AGen2integra)
jb weld will work. just make sure you let it set up long enough.
Old Sep 16, 2002 | 07:10 PM
Default Re: Need temporary fix for cracked radiator (cbaracing)
hell yeah thanks mang
Old Sep 16, 2002 | 09:58 PM
the DR.'s Avatar
permatex also makes a gastank and radiator repair thing, its like clay or something, u just kneed(sp) it together and apply it, works great
Old Sep 16, 2002 | 11:22 PM
88_SC_CRX_Si's Avatar
New User
Make sure the surface areas where the JB Weld, ect... will be applied, is throughly clean of coolant, paint, or any kind of residue. The last rad I repaired, I used some un-scented (if possiable) finger nail polish re-mover, it has "Acetone" in it. Which makes one of the best solvents to clean with. Evan using a tooth brush when possaibe, to reach/clean into the crack(s).
I have used it to clean my head and deck, when pulling/swapping head gaskets.... However, you will get some funny looks from the sells clearks tho... hehehe
Just a thouht...
[Modified by 88_SC_CRX_Si, 12:27 AM 9/17/2002]
Old Sep 17, 2002 | 06:10 AM
fuguman's Avatar
New User
i used a jb weld like substance whne the top tank cracked on the engine side. stoped the leak i was all happy and didnt even want to replace radiator. 4 days later it cracked on the bumber side .
be aware!
i got a new one on ebay (throught radiator.com) for $120 shipped.
Old Sep 17, 2002 | 07:13 AM
Default Re: Need temporary fix for cracked radiator (fuguman)
Thanks for all the responds back with help guys. I appreciate all of it. OH and this is definately not gonna be permanat, just gonna be a quick fix till I get money. Evan
wdissident
Feb 18, 2009 05:00 PM
sinnincivic
Jun 19, 2006 10:07 PM
93_teg_CT
Feb 7, 2006 11:18 AM
CRseXy
Mar 15, 2005 08:45 PM
91ls-v
May 6, 2004 07:49 PM
