PLEASE HELP!!!! Having trouble around 3,000 rpm's!!! Honda Accord 2000 EX
Old Aug 7, 2010 | 02:16 PM
SilverAccord04's Avatar
Default PLEASE HELP!!!! Having trouble around 3,000 rpm's!!! Honda Accord 2000 EX
PLEASE HELP!!!! I have a 2000 Honda Accord EX w/150,000miles, and recently experienced problems while driving on the hi-way when the rpm gauge reaches 3,000. rpm gauge doesn't pass 3,000. It seems to lose power, and doesn't want to accelerate any further. Even while flooring the accelerator I cannot gain speed easily. I have no problems with local driving around 30-40mph. My transmission was replaced by Honda 3yrs ago because there was a recall on my vehicle. Here is a list of things I need to do but haven't yet:
Check Engine Code: P1149-SI 02 Sensor
Check Engine Code: P1457 Evap System Leak
-I haven't changed the timing belt/water pump yet [/B]
Would the above be causing the problem or could it be something else? Any advice would be appreciated!!!!!!!
Old Aug 8, 2010 | 04:35 AM
poorman212's Avatar
Default Re: PLEASE HELP!!!! Having trouble around 3,000 rpm's!!! Honda Accord 2000 EX
The car is in limp mode. You'll need to correct the issues causing the codes. So in a way, yes the codes are causing the issue.
JDM_Mugen_CD6
Oct 2, 2016 12:35 PM
Boostedtegb20
Sep 11, 2016 05:21 PM
SilverAccord04
Aug 10, 2013 05:35 AM
CFP_IVAN
Nov 24, 2009 06:17 PM
JMc
Apr 6, 2005 09:55 PM
