do you think this idea will work ?
Old Aug 7, 2010 | 11:57 AM
miguey310's Avatar
Default do you think this idea will work ?
ok so as some of ya know the spark plug broke and i would have to take the head out to get it out , i was thinking if i use "J-B Cold Weld" to bond the SP together to take it out, so do ya think it would work ? Thanks in advance
Old Aug 7, 2010 | 12:25 PM
k20rex's Avatar
Default Re: do you think this idea will work ?
is the threaded part of the plug suck down there? i would try a long ez out or jb on the old plug
Old Aug 7, 2010 | 12:27 PM
miguey310's Avatar
yes it is , so do you think it's possible ?
Old Aug 7, 2010 | 04:12 PM
efjones9's Avatar
Its possible with a lil luck. Unless its really stuck in there
Old Aug 7, 2010 | 05:05 PM
miguey310's Avatar
already did it , now just to let it dry overnight
f22 killer's Avatar
Wow never seen that. Hope theres nothing in the cylinder. JB weld, pull the head, or ues an EZ out what about a left hand thread tap.
Old Aug 7, 2010 | 05:49 PM
FEDONV8's Avatar
There's a ford specialty tool just for this.
Old Aug 7, 2010 | 06:19 PM
miguey310's Avatar
what's it called ?
Old Aug 7, 2010 | 06:44 PM
75euRFE's Avatar
someone I know did this and when he started it up the compression from the cylinder broke the bond on the jb weld and shot the spark plug into the hood.
Old Aug 8, 2010 | 07:30 AM
chope045's Avatar
the same thing happened on my friends ford the jb weld worked for a while but after time the spark plug shot back out
Old Aug 8, 2010 | 02:26 PM
Canadian_EF's Avatar
He means using JB weld to REMOVE the plug.
salaamq
Dec 28, 2011 09:59 PM
psycheus
11
Sep 9, 2004 10:14 AM
Honissan
Jun 9, 2004 08:14 PM
Ef Whore
10
Apr 29, 2003 11:25 AM
B_CRUZ!
Feb 14, 2002 08:45 AM
