FS ek k24 swap nebraska WILL SHIP $2000
First off this is a K24a4 swap with 5 speed tranny, I wanted all the sensors/externals so I picked up an a3 which is included in the deal.
k24a4 roughly 60k miles (will give vin if someone needs to check)
k20a3 roughly 65k miles (same as above)
5 speed tranny
RSX full size radiator with fans
rsx shifter box
rsx shifter cables
rsx engine/charge harness
HASPORT BNIB EKK1 Mounts
SKUNK 2 Turbo cams k20a3/k24a4 BNIB
Karcepts clutch line(braided)
Karcepts radiator/res. relocate kit
Hasport coolant sensor adapter
Karcepts throttle cable set up
many new OEM honda seals/gaskets
PRB Intake Manfold
type s 310cc injectors
type s flywheel
pnd ecu
Longblock is complete with sensors/harness starter, alternator everything!
Located in Nebraska, willing to drive a decent distance if you can cover my 16mpg mountaineer or I can ship at your expense. Willing to part out if not sold in a week or so.
5 speed tranny
rsx shifter box
rsx shifter cables
PRB Intake Manfold
type s flywheel
pnd ecu
