For Sale/ Trade H22 Parts (Builders Bargain)
H22 Type S Bare Block - (30K, Fresh Hone, All holes threaded fine, no need for rethread, closed deck - exellent for boost) $300 (Negotiable)
H22 Type S Vtec Head - (No Cams, Injectors, or Camcaps, vtec solenoid in perfect working condition, perfect for someone trying to do a built head not a stock. Has aftermarket Springs, Valves and Retainers unfortunately I don't know the brand) - $300 (Remove Springs/Retainers/Valves for stock -$200)
JDM H22 Engine Girdle - ($150)
Type S Water Pump --- Brand new---- $75
Type S Oil Pump ---- Brand new---- $100
ARP H22 Main Stud Kit -----Brand new--- $100
Kaizenspeed Balance Shaft Eliminator Kit -----Brand new ----- $120
WIlling to trade for Specific B-Series parts, and high end D-Series Parts, must equate to the value of the part traded for, contact me here via PM or email - mrbellamythegod@yahoo.com or call (Don't text) 862 902 8855 ask for mike. Serious inquiries only. I call this the builders Bargain because if you're looking to go Hard on an H build these parts make an exellent foundation to start with, and their cheap.
Type S Bare Block -----30K, Fresh Hone, inspected, no cracks, gouges or bad holes needing re-threading, good to go, Closed deck, strong as an Ox-Good for a Boost app or N/A.--- $250
Type S Vtec Head ------ No Camshafts, No Cam Caps, No Injectors, everything else is there and good to go. Aftermarket Springs, Valves and Retainers, which brand, I have no idea, exellent if ur looking to build up a head, set of AM-Cams in and you're good to go. Vtec solenoid is in perfect condition, Head needs no resurfacing whatsoever-----$250
H-Series (96 H23 Prelude) Automatic Transmission, 50K, Works perfectly fine, no slips, rough shifts or non-functional gears work's totally fine. - $300
H-Series Water Pump -------Brand New-----$70
Type S Oil Pump ------Brand new--------$110
Kaizenspeed Balance Shaft Removal Kit ----Brand new-------$120
H-Series Block Girdle --------$90
Contact me via PM, Phone is off at the moment. Will be hard to get pics up due to my phone being off, but if u want pics I can provide within a few hours of inquiry. All parts are inspected, THOROUGHLY for defects, and are in working condition, I will not be beat for the "Oh it was damaged when I got it bit"..
WILLING TO TRADE for B-Series Parts, or high end D-Series parts. PICS avail. upon request.
You ran out of inbox space but the third quote is @ an overall price of 280 @ 2-3 days shipment through fed ex, which is the fastest..and the cheapest.
