need confirmation of ZC valve adjustment spec's
Old Sep 16, 2002 | 06:10 PM
gregv's Avatar
Default need confirmation of ZC valve adjustment spec's
hey guys
need confirmation for the valve adjustment spec's on a '91 DOHC ZC; I have the figures from the UK CRX manual:
intake: 0.005 - 0.007 in.
exhaust: 0.006 - 0.007 in.
I just had the valves adjusted at the dealer, and now the car runs fine but VERY hot. Geez, it ran fine when I brought it in...
(see next post)
Old Sep 16, 2002 | 07:39 PM
PeTeY's Avatar
Default Re: need confirmation of ZC valve adjustment spec's (gregv)
those are the correct specs.
Old Sep 16, 2002 | 07:48 PM
bottledcrx's Avatar
Default Re: need confirmation of ZC valve adjustment spec's (PeTeY)
if i remember right intake valve are set at .007 and exhaust at .009 they may chatter a little but it'll carry good vacuume at idle and should take care of cooling prob
Old Sep 16, 2002 | 08:03 PM
ScottEK's Avatar
Default Re: need confirmation of ZC valve adjustment spec's (bottledcrx)
all the sites I have seen recommend using a .006 for intake and .007 for exhaust, see Jason's ZC for dummies down at the bottom of the page.
Old Sep 16, 2002 | 09:09 PM
gregv's Avatar
Default Re: need confirmation of ZC valve adjustment spec's (beta13)
OK, I thought I knew engine basics, but I might be out of my league here;
If the valve clearances are set too tight, can this effect cooling? I think that
I have heard this somewhere, as well as it being stated in a reply to my
other posting. If so, do I just loosen them up a little????
I have confirmed from two other sources as well the previously mentioned
valve spec's, thanks all.
Old Sep 16, 2002 | 10:09 PM
HF2ZC's Avatar
Yes, it can affect cooling, if you make to clearance too tight. If you do this, the intake valve will stay open longer, thus heating it by the combustion of the air / fuel mixture. This is a Bad Thing, and something to avoid. It can lead to dropped valves and damaged valve seats. I'd set the intake at .006 and the exhaust at .007. The dealer probably didn't adjust the valves right, or tightened them down too far looking to silence the clatter. A little bit of valve clatter is normal and shouldn't affect anything.
Old Sep 16, 2002 | 11:05 PM
gregv's Avatar
Default Re: need confirmation of ZC valve adjustment spec's (HF2ZC)
good call; I have noticed on all my Civics that there is a definite valve clatter. After getting
it back from the dealer, it seems a bit quiet. Serves me right for not doing it myself...
thanks everyone for the info
Old Sep 17, 2002 | 01:16 AM
REX VT's Avatar
Download the workshopmanual..
Check under downloads..
http://www.hondacrx.co.uk/
91teg
Mar 13, 2004 05:14 PM
DevineCRX
Jul 29, 2003 06:07 PM
BseriesHatch
May 27, 2003 10:05 AM
jdmcrx2134
May 13, 2003 01:17 PM
CimorelliCRX
Mar 8, 2002 05:35 PM
