1990 prelude having starting issues
Old Aug 6, 2010 | 09:36 PM
melissavega's Avatar
Default 1990 prelude having starting issues
Ok I have a 90 prelude SI is having problems starting just makes some noise then putts like it wants to start i give it some gas a few times and it might start but this can take a while to get to the starting point. I thought it was cause there was grease on the belts but i took belts off and cleaned them and put some conditioner on them. also i changes the spark plugs and fuel filter just incase but it did not help also tried seafoam in gas to clean injectors. also at lights or while idled it stalls if i dont give it gas. Thanks for any help you can help me with. thank you so much
Old Aug 6, 2010 | 11:05 PM
Ziprock's Avatar
Default Re: 1990 prelude having starting issues
my friends 94 accord used to sputter and stall at stop lights sometimes, she replaced her spark plug wires and that fixed her problem.
Old Aug 7, 2010 | 02:56 AM
Tunerguy1989's Avatar
how many miles does your car have? Clean your throttle body (clean IACV if that model comes with it). Make sure there is nothing that is clogging you intake. there are three reason why a car doesn't start (or start properly) Air, Fuel, and spark, Check your Distributer and rotor, double check all spark plug wires for cracks or burn marks,(basicly do a full tune up inspection). And if your still having problems it could be trouble with your engine. Do a compression test and a leak down test to see the true condition of your motor internally.
Good luck
Old Aug 7, 2010 | 08:59 AM
thanks ill have hubby check it out when he gets home. A friend of mine said it might be a bad altornater but the lights work and dont realy dim or any thing does any one think that could be it dont want to take it out to be tested if i dont have to. i dont realy think my friend has a clue lol
Old Aug 7, 2010 | 11:50 AM
oh has 171000 on it sorry forgot
408h22a1
Feb 28, 2013 11:36 PM
rodriguez
May 24, 2008 05:26 PM
JDMBB2
Jan 22, 2004 09:23 AM
