NC: Super Advan SA3-R wheelsand Falken Azeni tires
Old Aug 6, 2010 | 03:03 PM
VegaS10's Avatar
Default NC: Super Advan SA3-R wheelsand Falken Azeni tires
Location: Fayetteville, NC (28356 for those Mapquesters)
Price: $1400 obo
Trades wanted: Authentic wheels, no knock offs or oem, nothing larger than 15
Wheel Size: 15 X 7 or 6.5 (not sure)
Wheel Offset: +38ish...per se
Lug pattern: 4 X 100
Tire Specs: 205/50/15
Wheel Damages: In description
Tires Included? (Yes/No) Optional
Wheel Brand: Falekn Azenis
The Good:
Rare and hard to find with all the pieces. All coins, coin lockers, center cap and center lugs are in place. Original finish with no rash or curbing. There is a couple of knicks here and there, but nothing worth mentioning. I also have the tool used to remove the large center lug so no damage is done. Tires have 85% tread with no camber wear.
The Bad:
During the last wheel removal, there was alot of dirt on the thread of the center lug. The dirt got lodged in there and stripped the thread upon removal. It was so bad, that I had to use a pair of oil filter pliers to remove the lug. I am still beside myself on this.
To fix it, I used a air dremel tool and removed all the threads on the center and lug. I drilled two small holes on the center hub and ran a cotter pin throuh (similar to 1999-2000 era styles). Most folks can't really tell and it holds everything in place nicely.
Pics as of this morning:
Front driver:
Rear driver:
Rear passenger:
Front passenger (the bad one):
To show lip depth:
Center lug removal tool:
Tool in place:
The damaged center cap stickers will probably replaced soon, as I will be repainting it as well. These are replica stickers as the originals were gone when I recieved them. I will be getting the wheels rebalanced soon as well.
If they don't sell (or trade), I may simply put extended lugs and lugnuts, and run the fronts without centercaps/center lug.
Trades (read this carefully):
No:
Rotas
Drags
OEMs
or anything larger than a 16.
I'm looking for authentic wheels only.
Something along the lines of SSR, Sprint, work, etc.
White with polished lip and magnesium blue make me smile.
I am in NO hurry to move these (as it took me two years to get rid of my eg hatch, I have the patience of a saint), so don't lowball me, as I will ignore you.
If you have any questions, feel free to ask, post, etc.
If you feel thses prices are too high, consider this:
The tires are $122 at discounttiredirect: http://www.discounttiredirect.com/di...w=false&cs=205
(Granted mine are used, but you get the idea...)
Wheels:
http://www.vrwheels.com/index.php?ma...oducts_id=1612
No centercaps, no larger outer lug, no coin, and no coin locker....plus shipping)
That's the only set I could find in a 4 X 100 bolt pattern. Most are larger, version 2.0, or 5 lug.
Thanks in advance.
slowata
Wheels
17
Feb 7, 2012 04:39 AM
VegaS10
Wheels
Nov 18, 2010 10:55 PM
jimmhatch
Nov 16, 2005 06:48 PM
RUBZERK
Dec 30, 2003 11:16 AM
