Honda CR-V & Element 2WD & 4WD Element & CR-V
^^coolant spilling on crv!^^
Old Aug 6, 2010 | 01:33 PM
AznDude's Avatar
Icon3 ^^coolant spilling on crv!^^
My gf's 1999 crv is spilling or spraying coolant. When i open the hood, there's coolant spray on the hood and near the throttle body. I refilled the coolant reservoir to full and proceed to drive her home and whenever I am at a stop, the temp gauge goes up and moves normal when I start driving When I checked the reservoir again, the was 1/2 gone within maybe 10 miles of filling up. Please help me pinpoint the problem. thanks!!
Old Aug 8, 2010 | 08:36 AM
Birdley42008's Avatar
Default Re: ^^coolant spilling on crv!^^
What year crv? Could be a cracked coolant line either from the motor or to the heater core. It could also be a cracked intake manifold or blown head gasket... is the oil contaminated? Could also be a leaking IACV. I am think it is malfunctioning hose from a crack or broke off. Take a look and find the source of where the coolant is coming from. Give us some pictures and a better description of whats going on.
Old Aug 8, 2010 | 08:59 AM
TTIWWOP's Avatar
When you have a coolant leak the best thing you can do is ask for help on the internet. We have a much better visual of the problem.
Old Aug 20, 2010 | 01:55 PM
EL Vap133's Avatar
What a useless response!
First thing I would check for is any leaks in the coolant system, make sure your fan and the switch are working. You can take it to a shop and have them pressure test the coolant system to be on the safe side. If they can find no problem then it is a possibility that you might have a small leak in the head gasket.
Kasheena Winn
Oct 28, 2017 03:21 PM
A-dub5513
May 18, 2009 04:08 AM
Morasso
Mar 11, 2007 07:14 PM
mrx
Jul 9, 2006 02:00 AM
sagaprelude
Feb 3, 2002 07:45 AM
