Rear wheel lag...
Hello all,
Well the short of it is, I just installed new trailing arm bushings in my 96 civic. Didn't have a press tool, so I had to disconnect the trailing arm (without disconnecting the brake lines) so that I could hammer the old bushings out and hammer the new ones in. Everything was a success, and I even took it in for an alignment where they said everything was still straight as an arrow even though I took out the toe bolt on both sides to remove the arm.
The problem is, when I drive now, I feel a pretty significant lag in the rear of the car. I was told by the mechanic where I took it in for an alignment that I might have messed up the ebrake cable a bit when taking the arm off and having it hang. How would one check for that, or better yet, could there be another reason for this lag? Thanks.
jash
16
Jul 12, 2010 03:55 AM
