NGK AFX Wideband wiring for S300
Hey everyone. I have an NGK AFX wideband (I heard they're a lot better after getting the new oxygen sensor, at least compared to the old one that was used). I also have an S300. I found this thread https://honda-tech.com/forums/engine-management-tuning-124/plx-m300-wideband-wiring-hondata-s300-2316071/ and was wondering if any of it pertained to the NGK. I'm colorblind so I try to stay away from the wiring stuff but simple soldering and such I can do. I also heard about changing it to a 5v source wire by maybe using the stock sensor plug or something. I don't really know. I'm just generally confused and am looking for any/all help you can give. Thanks.
this will be the same as most wb http://www.hondata.com/techplxwiring.html if you want to wire it to the eld read this http://www.hondata.com/forum/viewtopic.php?t=7300
thanks a lot. I am definitely more infromed now. I'll have to keep researching. I really want to get it installed since i have a 3" exhaust coming monday so we'll see. thanks
