master cylinder & O2 sensor ??
1: what year accord master cylinder to use on a 88dx and 89si.. ive heard of the accords work but is it a "plug in play" swap? and is it NECSSARY to upgrade the booster ??
2: i have the singel wire 02 in my b16a si (i only have 1 o2) which car to use for the 02 single wire, and what do they usually cost??
thanks in advance
thanks in advance
[Modified by MrDoHc2, 3:54 AM 9/17/2002]
from what I've read the 89 LXi (I believe, but corrret me if I'm wrong) will bolt up fine!
anybody elese what vouch for that befor i buy one?? thanks for the help man!!
what did you have to do when installing?did you get a brand new one, or a used one....will i have to bleed my whole break system again? thanks for the help. and also will an 89 dx crx work? i have a parts car that has one on it?thanks again.
Yes, you will have to bleed your whole brake system.
Yes, an 89 crx dx MC should work. Hold it up to your old one, the bolt patterns should be the same. The new ones do come with a new rod seal gasket...I dont know about the reliability of using a used MC...I'd go with a new one.
da9blk1
Dec 15, 2008 04:31 AM
h224thgensedan
Sep 27, 2006 02:11 PM
Jose-aka-Pedro
Aug 27, 2006 09:41 PM
