Black smoke from b16a2
Old Aug 6, 2010 | 08:54 AM
jj b16a2's Avatar
Icon2 Black smoke from b16a2
hi my coupe with a b16a2 just starting smoking black for my exhaust if anyone could help and tell me wat it can be
Old Aug 6, 2010 | 09:05 AM
forcefedferio's Avatar
Default Re: honda civic b16a2
Any CEL's? Any issues with driveability, stalling or sputtering? When does it do it? All the time? during VTEC?
Help us help you, i highly doubt any of us are driving behind you right now looking at your exhaust waiting for the smoke.
Old Aug 6, 2010 | 09:08 AM
95DC2GS-R's Avatar
usually black smoke is caused by unburnt fuel.
we need more info to help any further.....
Old Aug 6, 2010 | 09:35 AM
Former User's Avatar
Default Re: Black smoke from b16a2
Please make thread titles that reflect the issue. I edited your title to mention the main subject, which is black smoke.
Old Aug 6, 2010 | 11:55 AM
94civiccupew/b7's Avatar
could be a broken piston ring, or broken piston
Old Aug 6, 2010 | 12:04 PM
B16B4NG's Avatar
i was aware that a broken piston ring would burn oil indicating BLUE smoke, not BLACK...
like mentioned above.. black smoke indicates your car running too rich
Old Aug 6, 2010 | 12:05 PM
David12's Avatar
is the motor stock? or does it have an aftermarket fpr or injectors? is the car using the oem ecu? you haven't given enough information to help us help you. you should list the motor mods, so that we can rule things out
Old Aug 6, 2010 | 12:09 PM
sorry, I'm just speaking from experience
Old Aug 6, 2010 | 12:14 PM
B16B4NG's Avatar
ok, same here on an old civic i had, that's what i experienced too. Maybe i'm mistaken.
http://www.myhonestmechanic.com/arti...tailpipe.shtml
Old Aug 8, 2010 | 02:43 PM
unknownally's Avatar
I had black smoke, but now the smoke is now white. What's white smoke?
Old Aug 8, 2010 | 02:47 PM
Originally Posted by unknownally
What's white smoke?
Coolant
Old Aug 8, 2010 | 02:49 PM
Originally Posted by RonJ@HT
Coolant
I should've searched before asking. But yeah I searched and wallah.
It could be low, right? That's what I read.
Old Aug 8, 2010 | 03:07 PM
DVDr's Avatar
If you are puffing white smoke, then your coolant will be low. But adding more wont fix the problem.
you have a cooling system malfunction. ( probably Head gasket )
Old Aug 8, 2010 | 10:41 PM
SOHConthis's Avatar
white ...coolant
blue...oil
black....google it homie some on here think its to much fuel but almost any stock gsr motor does that i heard that it might be ur valve seals goin bad...
Old Aug 9, 2010 | 12:29 AM
95DC2GS-R's Avatar
Originally Posted by SOHConthis
white ...coolant
blue...oil
valve seals that leak cause oil being burned in the exhuast and makes blue smoke, not black.
Old Aug 9, 2010 | 12:42 AM
DCRB's Avatar
i've seen lots of em1s do this. i thought it was just a "vtec" thing...
Old Aug 9, 2010 | 02:12 AM
Nichelson_Performance's Avatar
black smoke is unburnt fuel indicating something causing a rich air/fuel mixture.......probably an o2 sensor if your car is pretty much stock
this has nothing to do with burning oil, if oil was being burnt the smoke would be blue. if coolant is being burnt the smoke will be white
please list mods if your car has them
Old Aug 9, 2010 | 02:18 AM
I checked again, smoke is black according to my fiancee. I'm like color blind LOL.
Anyways,
my mods... DC CARB legal header. Also for some odd reason the cat back is welded to the cat.
Old Aug 9, 2010 | 05:01 AM
Any CEL's....possibly a stuck injector or something wrong with your fuel pressure regulator...or an o2 sensor problem
Old Aug 9, 2010 | 05:27 AM
jacki eg6's Avatar
id say o2 sensor had same brob on my b18, changed it n its fine now
Old Aug 11, 2010 | 03:15 AM
my o2 sensor doesn't seem right.
The wire is super long. It's wrapped around other wires in the harness so it wouldn't hang.
Old Aug 11, 2010 | 07:26 AM
B16B4NG's Avatar
well, when they installed the b16 they probably had to lengthen the wires to reach the o2 sensor bung near the bottom. Did you get an o2 cel?
Old Aug 12, 2010 | 11:55 PM
I'm not the OP. Mine is a stock GSR original motor.
Had a coolant temp sensor CEL but fixed it and cleared it.
Old Aug 13, 2010 | 04:46 AM
devney's Avatar
white ...coolant
blue...oil
Don't speak if you don't know what you're talking about.
Old Aug 14, 2010 | 01:36 AM
i think a lot of GSR's are just abused. That must be why a lot of people think it's a VTEC thing. My brother also said it was a VTEC thing. He been through 3 GSR's lol
